markus0321 wrote: Tue Oct 18, 2022 11:11 pm
There is also an improvement with a soft reset, because it works when I use flash, but with EmuTOS, when I turn off flash and TOS4.04 is working from the motherboard, unfortunately, after a soft reset, TT-RAM still disappears and just like I upload TOS4.04 to Flashrom it also disappears: - (
A soft reset doesn't work with TOS4.04 hm ..
If you're using MAPROM, then I think this is a bug in the latest version -- it only works after a cold boot. That was an old bug that was fixed and appears to have come back.
Try v2.2 (attached).
Thank you so much. Now it works great!
What I had before was a completely different maprom program.
I downloaded it from here: https://github.com/agranlund/tftools
I think you need to fix it in the official Viki to DFB1 or attach the new one?
Now works fine and speeds up the ROM even more.
Works fine with TOS4.04 and EmuTOS
Badwolf wrote: Wed Oct 19, 2022 12:58 pm
However the fact you're getting *half* an Atari logo sounds like bus conflict. I'll try to scope my ROM chip enable line either tonight or tomorrow.
I've scoped my ROM2 line -- no bus conflict evident. Once EmuTOS is booted from the flash, or once NVDI loads from TOS4, no further onboard ROM activity is seen.
I think I'm going to release this firmware officially.
DFB1 Open source 50MHz 030 and TT-RAM accelerator for the Falcon Smalliermouse ST-optimised USB mouse adapter based on SmallyMouse2 FrontBench The Frontier: Elite 2 intro as a benchmark
I checked gembench and NVDI TOS4.04 graphics performance with agranlund maprom
"https://github.com/agranlund/tftools"
is much bigger. This maprom 2.2 from you works fine, but it's missing something. Maybe the agranlund one could be improved so that TT-RAM does not disappear after the reset?
Marko
Sorry for the error, I am still learning about Falcon's operating system and forgot to set the boot order in AUTO. Maprom must be first, before NVDI and then the performance is at a similar level as before
markus0321 wrote: Thu Oct 20, 2022 12:23 am
They are both Anders' program. I've just given you an older version that doesn't have this bug. When Anders has time I'm sure he'll have a look at what's going on for us. I've raised an issue on his GitHub page.
Of course, if you've any experience with software development, since it's open source, you're welcome to take a look yourself.
Unfortunately, I'm not good at coding I'm better at soldering and repairing the hardware.
Thanks for the useful information, I'll be checking from time to time if there is any software fix for DFB1.
This is a really great card for Falcon and it's very nice to build.
Hello.
I partially assembled the second DFB1. I haven't mounted 245 and RAM buffers yet. In this case, if I have Flash soldered, can it work without the SN74cb3t3245 chip?
I compiled the last version of the nightly EmuTOS with Falcon settings and RAM test enabled.
Maybe it will be useful to someone (for me it works correctly with DFB1, as long as the firmware from this thread is programmed in DFB1).
Hello.
Flash should work (it's 5V). TT-RAM won't as these are the level shifters on the SDRAM data lines.
I tested the second DFB1 board and detected a problem with data transfer from scsi drives. This manifests itself in the fact that when trying to unpack a zip or lharc archive, errors occur during decompression. This only happens when the TT-RAM memory is active, I now have 2 pieces of DFB1 and the same on each. There are also problems when I tried to run large programs loaded on a SCSI drive or install NVDI on a SCSI drive. The same things work fine when run from the IDE drive. What can be the cause of bad data transfer from SCSI drives?
