so first up, it seems to have some weird reset issue. Occasionally it would boot up..
- IMG_0062.JPG (450.37 KiB) Viewed 1672 times
- IMG_0063.JPG (158.12 KiB) Viewed 1672 times
- IMG_0064.JPG (234.83 KiB) Viewed 1672 times
I found C100 is basically limiting the reset voltage to just 1 volt! so for a quick fix I just slapped another over the pull-up and to actually reset properly!
- IMG_0066.JPG (300.76 KiB) Viewed 1672 times
The next problem is, it seems to be suffering from that "Shifter goes nuts" problem.
- sgn.JPG (103.5 KiB) Viewed 1672 times
On this machine it does not seem to matter which version of the video shifter is fitted.
In any case I managed to get it run long enough to run a pass of GB6.
- IMG_0070.JPG (295.85 KiB) Viewed 1672 times
- IMG_0071.JPG (589.17 KiB) Viewed 1672 times
It is indeed a very poorly STE. With a lot of TLC I think it can be brought up to fully functional. Though I will probably used as a guinea pig for 16Mhz buffer tests when/if I get time.
