Hello, I have converted a Nintendo NES controller using this guide.
https://raskulous.com/2020/02/convert-a ... ny-others/
I was always a joystick fan but I thought a gamepad would be a little easier on my less than perfect left hand. So it worked fine and it is very responsive, pleasant to use. Anyway after a while the fire button didn't work anymore. I couldn't think why. After some time deliberating I realised that I had changed the mouse from an Atari mouse to wireless USB adapter, this one to be exact:
https://gossuin.be/index.php/smallymouse-2-atari
When I plug in the Atari mouse it works again. I assume that means the USB adapter is messing with a contact or maybe drawing too much current or something like that. Anyone know more about the cause , perhaps?
Gamepad fire button depends on mouse
- russellnash
Re: Gamepad fire button depends on mouse
If it's anything like the Tom adapter then it has a hard pull-up on the right-button line. This is the same as the joystick button and will put so much current onto the line that it never gets low enough to trigger the ST's detection for the button being pressed. It's a major design flaw. They should have used some sort of open collector chip.
How I solved this for the Tom adapter was to put a cable between the ST and the adapter and a diode on the right-button wire so that the adapter could never supply current to the ST on that line, only sink it.
- russellnash
Thanks, I knew someone probably had a similar thing happen. Interestingly, when I try a joystick it does fire and only has the problem intermittently, which made me think that the switches are maybe faulty, but I guess not. Good to know.
You're lucky it doesn't hard reset the machine (or worse) as you're shorting 5V to GND when you press fire.
The latest firmware from Simon Inns has removed this bug after it was reported.
https://github.com/simoninns/SmallyMous ... -583753980
But I wouldn't know if the original firmware would be compatible with Olivier's board design. The same goes for my firmware. I doubt it would work with Olivier's board.
Unfortuntely, with a board that small, there's little scope for a hardware fix (putting a diode on the RMB line).
It's designed to be shorted. There's a 10K pull-up on it, so there's actually 10K ohm resistance to Vcc.
The problem is when the Smallymouse drives it at VCC on one port and you then short it with the fire button on the second port.
You've basically put the 1287 in parallel with the 10k pull-up (rendering it irrelevant) and the chip is trying to source enough current to raise GND to VCC.
If the chip is able to supply enough current to lower VCC, the machine cuts out. I've tested it with the original firmware and it happens for me.
One of the first changes I made with Smalliermouse was to switch the ports to input when not emulating a mouse click (ie. simulating an open drain).
- russellnash
It is all useful information, thank you. I will live with it first of all until perhaps at some point in the future I get annoyed by it and then we will see.
