New bar arrived this morning. So been busy trying to figure out how to get it all to fit together. This all literally took me 12 hours straight
First problem is of no surprise. This slidey bit was too wide, so I had to move the whole mechanism forward on some nuts and washers.
- IMG_0169.JPG (205 KiB) Viewed 2336 times
- IMG_0170.JPG (210.14 KiB) Viewed 2336 times
I moved the L brackets to the front because I could space them out better this way.
- IMG_0171.JPG (242.79 KiB) Viewed 2336 times
Next problem was finding more bolts to fit the idler mechanism. Also spacing that forward.
- IMG_0172.JPG (222.08 KiB) Viewed 2336 times
- IMG_0174.JPG (266.22 KiB) Viewed 2336 times
Now I needed to flip the drive gear on the motor which proved practically impossible to undo the grub screws
I eventually managed to get one of them three but the other one must have been rammed in there so hard at manufacturer it was just simply never going to come out. Basically I ended up just bashing the thing until it came off. It looked like it was plastic but it is as strong as metal.
Thankfully I had a spare which was the right size anyway.
- IMG_0175.JPG (239.88 KiB) Viewed 2336 times
The problem with the head bracket is that it physically fits to far forwards now.So I could not use the clamp for the belt any more
I ended up using the hole from the bottom idler wheel and placing a bolt there. I hacksawed a spare bracket down and clamped that to the bolt.
- IMG_0176.JPG (369.16 KiB) Viewed 2336 times
The next problem was there was no way to clamp the belt onto this new plate. So I just had to order a longer belt. Then I can wrap it around and simply cable tie it together so it cannot move.
- IMG_0177.JPG (194.71 KiB) Viewed 2336 times
Currently this is where we are at.
- IMG_0178.JPG (254.72 KiB) Viewed 2336 times
The head is now mounted back on. I just need the belt to come tomorrow so I can hook up the X-axis again. I also need the Z-sync belt to come yet.
I have a new magnetic bed *somewhere* which I also need to swap out. Hopefully this will solve the two biggest problems with the printer overall.
