Project: HDMI/DVI out for STFM
Progress on our FPGA cores.
nokturnal wrote: Sun May 30, 2021 12:03 pm I have one suggestions for this design (I'm not sure how final this design is). I dislike connectors directly soldered on board .....
The board you're referring to is designed to fit H5 series motherboards. There is a separate project in development for original machines which has the connector on a cable as you describe. There will be more threads on all this in due time.
nokturnal
Post by nokturnal »
That's great, I just saw earlier photos and I thought that this desing evolved in that way. On those newer motherboards, socket on pcb really makes sense.
nokturnal
www: https://nokturnal.pl
As you know I have been working on the H4/5 version Phoenix Shifter but from that I have spun off an STFM version.
As you can see there is now a ribbon cable that actually fits well under the video circuitry can hinges so you don't have to remove the lid and it will shut properly. Render below shows folded cable but it can go under the back hinges.
STFM Motherboard with routed Phoenix Shifter.png (2.75 MiB) Viewed 7493 times
The HDMI connector is on its own small board which allows fixing where is best for the user to get the port out of the case.
The boards are as small as I could get them. My goal was to try to fit it all in the foot print of the original shifter but I couldn't quite make it. I think its small enough though. Example of the two versions below H4/5 and STFM:
I am in the middle of building up these boards to test but you get the idea how these will work and how small they are.
Impressive work for sure :dualthumbup: :dualthumbup:
That is impressive. Of course this would be useful for any traditional ST with a DIP Shifter, not just the STFM.
stephen_usher wrote: Mon Jul 26, 2021 1:49 am That is impressive. Of course this would be useful for any traditional ST with a DIP Shifter, not just the STFM.
Indeed. Any DIP shifter can be replaced. In fact I intend testing this board in my 520ST.
Post by JezC »
Looks really good @Icky
alienkidmj12
Post by alienkidmj12 »
this is sure looking mighty good :)
PaulJ
Post by PaulJ »
Pretty cool Icky. Would like to put one in my Mega4. :dualthumbup:
Return to “FPGA DEVELOPMENT”
