Well, I've glued up and cleaned the F2. There's only one bit of case which obviously escaped the box on the way here.
I swapped over the floppy drives so that the problematic A drive became the B drive and put everything back together.
It looks a lot better now:
- IMG_2308.jpg (72.78 KiB) Viewed 3497 times
However, after powering on and booting I put a floppy into the B drive to see if it would format any better after I'd lubricated it...
Floppy went in, the screen went blank and corrupted and smoke came out of the B drive!!!! A component had gone bye-bye and shorted!
Opened the machine up again and disconnected the B drive and the machine boots. Interestingly, whereas before the BIOS was reporting 1440K drives (which they aren't) it now correctly reports 720K, so it looks like whatever component was dying made the machine think it had bigger drives. Unless, of course, what it's actually reporting is the total drive space, i.e. 2x720K for two drives.
