I have done a small PCB so that you can make your own HD cable. Compatible with Lotharek's PCB. Thus this also works with UltraSatan (Tested with US). I don't know if it has the same pin out as Oliviers DMA cable though. I haven't tried it. I have made two different variants of the board. I have use the one with bigger holes in the instruction below. You can also use loose pins.
Big hole PCB Gerbers.
Standard hole PCB Gerbers.
WARNING: Longer cable might/probably need pull-up resistors on the data lines on the DMA. Otherwise corruption might occur. If the cable are used on a Mega STe/TT then make sure it is not shorted on the port above the ASCI port.
Parts needed:
- One IDC 20 pin Female to IDC 20 pin Female cable in the length you want (shorter is better) or make your own.
- Two PCB (or one if your doing a Ultra Satan cable).
- Two 25 Pin D-Sub Male connectors for cables (or one if your doing an Ultra Satan cable).
- Two 20 Pin IDC Male Connectors (or one if your doing an Ultra Satan cable).
How to make it:
Remove 6 pins from one side of the DB25 connector by pulling it out with a pair of pliers from the solder side. Cut away the metal housing around it. Cut by the two holes at end and it should come apart. Cut away the end plastic were you removed the pins to make the connector a 19 pin D-Sub. I have made some red lines below so you can see what I mean. Sand it if you want it it to look nice.
Push in the DB19 you made into the PCB. It's a snug fit and it will not sit flush with the PCB. Solder the connector and then the IDC connector to the board.
Clean the board with IPA (Isopropanol), connect and try it out!
