A1000 and TF536 with CF card
- JackTheKnife
I just got TF536 card with intention to put into A1000 but I'm not able to boot it with CF card connected to it. A1000 will stay in the black screen.
When I will disconnect and boot from the gotek, or just leave no "floppy" inserted, it will boot fine to the Workbench or Kickstart screen.
TF536 is on top of KuickStart II board with Kickstart 3.1 ROM as a default to boot.
Any thoughts on that? Probably, if I will find some spare time, I will check TF536 with A500 over the weekend to rule out card issues.
Thanks
Thanks
- Admin sponsor
Re: A1000 and TF536 with CF card
Most likely an incompatible CF card.
No, this is one of mine and I shipped it with a tested CF card which booted fine on my A500. Something else is up here.
The only thing that comes to mind is that somehow the CF card got loose during transport and is not making full contact...
- JackTheKnife
Yes - I have tried to re-insert CF card, no luck. Also there is no LED indicator when booted with CF card connected to the board so my first thought was about not enough power is getting to the CF reader so it may need to required some wiring from the board to have it up and running.
As I wrote before - I will check it with A500 if the time will permit over this weekend.
This could be a PSU problem, the TF card could well be tipping yours over the edge.
- JackTheKnife
How can I verify that?PaulJ_2.0 wrote: Thu Oct 29, 2020 2:32 pm This could be a PSU problem, the TF card could well be tipping yours over the edge.
Check the +5V isn't going below 5V for a start. If the PSU isn't powerful enough the voltage will drop. Better to use an oscilloscope as the drops can be brief when something momentarily draws more power.JackTheKnife wrote: Thu Oct 29, 2020 2:58 pmHow can I verify that?PaulJ_2.0 wrote: Thu Oct 29, 2020 2:32 pm This could be a PSU problem, the TF card could well be tipping yours over the edge.
- JackTheKnife
OK, it came up that A1000 works fine only with SanDisk CF 8GB card
No clue why but it may be needs more power as TF sits on top of KuickStart II board. Probably that setup will need CF adapter which has external power source like that one: https://www.ebay.com/itm/Compact-Flash- ... 3145920489
Also I'm looking for CF adapter suggestion which can be installed directly to the TF board as with the cable is hard to fit in A1000 as it will go on top of FDD metal holder (as you see on the photo) or will hang over CPU which I think is not good idea.
- Admin sponsor
Original A1000 PSUs are not great.
- JackTheKnife
Just an idea which I have brought to life as the other way is a that piece of a metal floppy caddy
