TF CD32 Riser
makaron wrote: Mon Nov 16, 2020 9:32 pm
I built new card today.
I haven't ordered 100k resistors on video line (installed biggest I had 20k for now), but video is badly overexposed and colours do not match, video is very soft.
I will try with 100k in few days and will let you know.
I think the resistors need to be 75R but i'll check. those are pull down resistors to ground IIRC.
NOTE: never trust any values i put in schematics.. i never set the values until after i build it.
makaron
Post by makaron »
terriblefire wrote: Tue Nov 17, 2020 8:50 am
I did suspect that this might be the case. (datasheet has 75R)
PS
I need to order smd resistor set, it starts to annoy me that I never have right values and need to wait ages for delivery..
makaron wrote: Tue Nov 17, 2020 10:26 am
PS
I get the £9 assorted sets with 20 of every value
Somthing like this
https://www.ebay.co.uk/itm/2000pcs-0-oh ... SwW2RdMYAx
makaron
Post by makaron »
@terriblefire
I did find few resistors 68R
There are some small differences but maybe resistor values migh need to be better adjusted if someone is looking for perfection? Anyway it is good enough for me.
Unbuffered
Buffered with 68R
And I fuc**ed up order. I ordered wrong usb stacked connectors (usb 3.0), and destroyed my other one when I tried to desolder it from old board. Another few days wait for parts now :D
makaron
Post by makaron »
I am not too patient. I trimmed "spare" legs on stacked USB which I got, and it works both HS and FS.
I need to update firmware to changes in pin wiring.
I don't have any spare 1220 batteries at home, ordered some today. Need to complete and test RTC support.
makaron
Post by makaron »
Managed to start it. :)
I had some hiccup with RTC LSE, it needs different config to start. Using default values it was unstable - which caused hangs for some reason, when values were written to RTC registers. (RTC init was in constant never ending loop).
Waiting for battery to make sure that time is kept even in power off mode.
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
Another few elements working (keyboard).
Few minor bugfixes with managing registers have been added.
Unfortunately still don't know why cd32 pad is not being detected correctly.
I am setting up cross compiler to modify ATK to show me what exactly is being read and why it doesn't pass detection. ... but setting up compiler is painful and takes ages!
~ Stanislaw Lem
arkadiusz.makarenko wrote: Thu Nov 19, 2020 12:12 am Another few elements working (keyboard).
IIRC the ATK can be built on a generic compiler that you can apt-get install.
arkadiusz.makarenko
Moderator Team
Moderator Team
My opinion on compiling cross compilers from source...
~ Stanislaw Lem
arkadiusz.makarenko wrote: Thu Nov 19, 2020 1:19 pm My opinion on compiling cross compilers from source...
Or you can use the prebuilt docker container. :)
Return to “TF CD32 Riser”
