A TF536 Riser For The A500 and A500+
68030 + SDRAM + IDE
go0se
Re: A TF536 Riser For The A500 and A500+
Post by go0se »
Danoo wrote: 26 Aug 2020 09:50 Thanks for this riser @go0se I ordered a batch of 4 layer ones from JLC, and they arrived a few days ago, really work very well in my A500+. Really like how the ide port lines up perfectly with the expansion port exit. Have tried with a lot of different software, no problems at all :thumbup:
Glad it's working well for you @Danoo and good choice going for the four layer version! I've been using them for a while and they seem pretty solid. The expansion port alignment was kind of a fluke. :)
Make sure you clip back the underside of the D5-D12 receptacles that sit above the Agnus and apply some tape underneath to prevent any issues.
Danoo
Post by Danoo »
go0se wrote: 26 Aug 2020 11:18 Make sure you clip back the underside of the D5-D12 receptacles that sit above the Agnus and apply some tape underneath to prevent any issues.
Yes I did noticed that possibility before I powered up, already have a couple of strips of electrical tape on the underside terminal connections above the Agnus :thumbup:
alenppc
Moderator Team
Moderator Team
Post by alenppc »
PaulJ_2.0 wrote: 16 Mar 2020 22:21 Ah great stuff, I've been wanting rom clearance there for ages.
Not on rev5 motherboard though (the most common one). But it doesn't matter really, I always thought kickstart switchers are useless.
go0se
Post by go0se »
alenppc wrote: 26 Aug 2020 12:58
The revision5 A500 ROM layout feels like it has been deliberately designed to thwart any attempt to fit a TF536. I did intend to come back to it and see if I could produce something REV5 specific that what a lot more satisfactory, but I got distracted.
I encounter a lot more 6A and 8As, but that's just based on a sample of me. Perhaps the 5 is more prevalent in North America.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
go0se wrote: 26 Aug 2020 13:19
Yeah, about 90% of A500s I encounter here are rev5s. Very rarely I see a rev6 and I don't think the rev8 was ever released here.
Lynxman
Post by Lynxman »
This relocator looks great. Clearance on Rev 5 would be good for adding EEPROM adapters for those who can't or won't modify the motherboard itself for EEPROM compatibility.
Return to “TF536”
Users browsing this forum: ClaudeBot, Google [Bot] and 3 guests
