Glad you liked it! for setting the speed I just wrote a set of four one line scripts to launch Steve's application with a particular speed 50,62,75, and 100 and made a custom icon for each so you run the 50Mhz one and it set it to that. I'm happy share to and plan on posting the scripts/icons just finishing the icons they need a little cleaning up will post them soon.supaduper wrote: Sun Aug 02, 2020 8:19 am And another happy TF360 owner, he has done some nice touches with his self made Terrible fire box and stickers and wrote a nice executable app for Steve`s CPU SPEED program which hopefully he will share
TF360 Status
Re: TF360 Status
C128/A3000/CD32/A1200 -https://www.youtube.com/c/32Bits
Re: TF360 Status
Ok, have the icons ready but I'm not able to upload .lha files so I zipped the Lha file and uploaded that
. You will have to unzip the attachment then unpack the lha inside .
Re: TF360 Status
Thanks 32Bits mauch appreciated
Re: TF360 Status
Cheers, a simple and effective idea with a stylish implementation.32Bits wrote: Mon Aug 03, 2020 10:40 pm Ok, have the icons ready but I'm not able to upload .lha files so I zipped the Lha file and uploaded that. You will have to unzip the attachment then unpack the lha inside .setspeed.zip
Re: TF360 Status
Happy to be able to give even a little back..
Re: TF360 Status
Thanks , Glad you like itsugar wrote: Thu Aug 06, 2020 9:38 amCheers, a simple and effective idea with a stylish implementation.32Bits wrote: Mon Aug 03, 2020 10:40 pm Ok, have the icons ready but I'm not able to upload .lha files so I zipped the Lha file and uploaded that. You will have to unzip the attachment then unpack the lha inside .setspeed.zip
OHROM
Re: TF360 Status
Finally got my TF360 Firmware upgraded so my clock port works now. Big Thanks to 32Bits for helping me out was a late night remote session to get it done. I downloaded the latest raspbianbuster i think it was, installed it, ran the checks like the instructions said and i got this this error "Can't find description for cable named sysinfopio " then a bunch of results below it. So went back and rechecked all the connections thinking it might be that nothing same thing. then figured maybe download an older version same error. we were just about out of ideas when 32bits went to google and found someone had the same problem might even been here on exxos. and just to find out they changed then name in the code to sysfsgpio_creator omg! i couldn't believe how much time i wasn't on this. but once we have the correct name everything installed ok. and now my clockport working fine. new project will be the wifi addon already bought it just got to program it i think. And most likely gonna need 32bits help on that one too
- Admin sponsor
Re: TF360 Status
I updated the wiki here
https://github.com/terriblefire/tf328/w ... spberry-Pi
Surprised nobody has updated it
Re: TF360 Status
Can I shoot a question about this, because I got half way and then couldn't joint the dots.terriblefire wrote: Sat Aug 15, 2020 4:51 pm I updated the wiki here
"Wiring up the RPi to the TF328"
So the WIKI has the pin outs on the TF328 in a column, and next to it the BCM numbers for the RPi. Then we have 3 diagrams showing the pinouts on the different versions of RPi. But the pinouts dont have these BCM numbers, instead GPIO numbers.
So at this point.... how to you wire up the RPi to the JTAG header?
Re: TF360 Status
Matt, here is a link on EXXOS in the posts there is my Howto, and in another post there also a link to my 8gb Raspian image which has the programmer on it ready to go. the password is: Backlash1
https://www.exxosforum.co.uk/forum/viewt ... 8&start=10
