TF536 on the ST
Other boosters or variants.
Re: TF536 on the ST
terriblefire wrote: 31 May 2020 22:36 Ok looks like the same issue. How do you stop GLUE decoding it though? I read the relevant comments but didnt notice that.
Likely just stopped GLUE from seeing /AS... That way GLUE doesn't see the address and no DTACK!
terriblefire wrote: 31 May 2020 22:36 Needs a decoder. Exxos is working going to be selling them soon.
First runs are already in my store.
https://www.exxosforum.co.uk/atari/store2/#0172
Re: TF536 on the ST
exxos wrote: 31 May 2020 22:41 Likely just stopped GLUE from seeing /AS... That way GLUE doesn't see the address and no DTACK!
My instinct was that if i did that then the YM wouldnt get decoded.
Purchased.
Re: TF536 on the ST
terriblefire wrote: 31 May 2020 22:50 My instinct was that if i did that then the YM wouldnt get decoded.
I decoded the YM address range in my PLD logic and just bypassed GLUE. https://www.exxosforum.co.uk/forum/viewt ... 370#p17550
This is why there is a SND_CS jumper on the H4 ;)
Re: TF536 on the ST
exxos wrote: 31 May 2020 22:55
Ah now i understand. I have to find a different solution in the TF536. Its main design goal is plug n play.
Re: TF536 on the ST
Does anyone have a minimalist HD image i can DD onto a cf card which is known good with TOS2.06?
Re: TF536 on the ST
terriblefire wrote: 01 Jun 2020 19:00 Does anyone have a minimalist HD image i can DD onto a cf card which is known good with TOS2.06?
I suspect most of the guys will use the HDDriver which is paid for, as I do myself.
I have a couple of 4gb Ultrasatan images (840mb) which should work if nobody else has something a lot smaller.
Re: TF536 on the ST
PhilC wrote: 01 Jun 2020 19:13
Hmmm. Nobody using TF534 IDE? :/
Re: TF536 on the ST
terriblefire wrote: 01 Jun 2020 19:17
I've been struggling to get it to work on my Mega 4
Re: TF536 on the ST
@terriblefire
Actually I should explain a little more.
I'm waiting on a decoder board from exxos, so when that arrives I will make up a simple boot image for the TF534 & 536's. My problem is that I'm having to use an IDE board as a decoder at the moment which obviously doesn't let the TF board work.
Hopefully @agranlund will have a small image to get you started?
Re: TF536 on the ST
I think im too spoiled with WinUAE. It can access a CF card like its a raw IDE drive.
Return to “EVERYTHING ELSE”
