Which a500 card
EzdineG
Re: Which a500 card
Post by EzdineG »
alenppc wrote: Thu Aug 22, 2019 1:28 pm Hmm you are right... I dug up a bit more, and you are right, the mufastrom doesn't reboot, but I still get 2 reboots with the mutools enabled. I have to figure out what's causing it.
It may have more to do with where in the startup-sequence it is than anything else. The installer puts it in user-startup, I always move it right behind setpatch.
With 3.1.4.1, I have 0 reboots and my system is up in seconds (NODRIVELEDPATCH) .
Bikerbob
Re: Which a500 card
Post by Bikerbob »
arkadiusz.makarenko wrote: Mon Aug 19, 2019 12:50 pm Tf530 is obsolete.
TF534 is just made obsolete
TF536 is on hold just now (hopefully not forever)
So really you don't have much choice.
Ps. I am in the same place. Debating if I should build TF534 or "risk" and wait for TF536
Please explain that statement? Obsolete? What makes the Tf530 obsolete?? A500 was made obsolete in 1994???
Whats wrong with putting a Tf530 board in a A500?
James
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: Which a500 card
Post by arkadiusz.makarenko »
Bikerbob wrote: Tue Dec 10, 2019 2:22 am
James
Nothing wrong. Read this below.
https://www.exxosforum.co.uk/forum/viewt ... =68&t=1888
Ps
I did build TF534 + 8mb 68kmem great combo!
~ Stanislaw Lem
Bikerbob
Re: Which a500 card
Post by Bikerbob »
arkadiusz.makarenko wrote: Tue Dec 10, 2019 6:49 am
James
Ps
OK.. lol.. so I read that thread.. and I get that TF530 and TF534 are crap.. abondoned because they were more trouble then they were worth?
SO I am a little confused... or a lot.
Thanks
James
Re: Which a500 card
These cards are experimental boards.
Buy a Witcher 500 if you want a simple A500 experience.
xraynorm
Re: Which a500 card
Post by xraynorm »
Hi.
Is this from one of the official sellers?
https://www.ebay.co.uk/itm/TF536-68030- ... Sw2rNfO6sA
Re: Which a500 card
xraynorm wrote: Tue Sep 08, 2020 8:27 am Hi.
Of course... its my wingman go0se.
EDIT: if you pm him here you may be able to get it without ebay taking their cut.
xraynorm
Re: Which a500 card
Post by xraynorm »
Great. I'm planning to use a short IDE cable (10-15cm). Will I need the IDE buffers?
Thanks
Re: Which a500 card
xraynorm wrote: Tue Sep 08, 2020 8:37 am Great. I'm planning to use a short IDE cable (10-15cm). Will I need the IDE buffers?
Thanks
15cm is a long cable. The answer is unknown at that length.
Chucky uses a TF360 with almost a 1M cable with no buffers. Other people say 5cm doesnt work.
xraynorm
Re: Which a500 card
Post by xraynorm »
Thanks for the info.
Is there any disadvantages to having the IDE buffers installed on the card?
