Indeed. I have a horrible feeling that the Rev 0 might not allow the 020 to be disabled.alenppc wrote: 13 Mar 2019 22:06 Consoldering the CD32 was hastily built as a company saviour they probably didn’t do the usual diligence. Maybe it’s not possible to detect different revisions via software.
TF330 Akiko Rev 0 Issue (SOLVED)
- Admin sponsor
Re: TF330 possible issue?
Gooeyblob
What about the Akiko mirror addresses...?
- Admin sponsor
I dont follow.
Gooeyblob
Is the same Akiko identifier present at B80040, B80080...B87FC0?
- Admin sponsor
I suppose its worth checking but i would be incredibly surprised if the 64 byte mirrors had different data. Usually with these things its because they cheaped out on the address decoding.
Gooeyblob
Another address that may be worth checking between revisions are bits 0 to 22 of Config/B80024.
alenppc
- Moderator Team
My gut feeling is that 020 does get disabled, but then something else in the logic is different. The behaviour is consistent, yellow screen, flashing led, black screen, flashing led, yellow screen. If both CPUs were on, I don't think we would be seeing this.
I don't know anyone else with the SX32 AND a rev 0 Akiko... but surely this would have popped up sooner if that had been the case.
- Admin sponsor
My thought process...alenppc wrote: 13 Mar 2019 23:39 My gut feeling is that 020 does get disabled, but then something else in the logic is different. The behaviour is consistent, yellow screen, flashing led, black screen, flashing led, yellow screen. If both CPUs were on, I don't think we would be seeing this.
There are 3 ways the TF330 interacts with Akiko..
(i) It holds CPU_BR low for all time.
(ii) It uses EX_BR/EX_BG for bus arb in place of CPU_BR/CPU_BG.
(iii) it expects PUNT to disable all the decodes on the mobo.
The only other weirdness might be the FPU detection code in the OS. Since people are reporting DiagROM going mad when accessing Fastram i cant see how any of this relates to Akikio. Unless PUNT is non-functional somehow or the 020 is still running.
When the TF330 accesses Fastram it simply tells the Amiga to shut up.
I'm very confused at this point.
alenppc
- Moderator Team
It would be helpful if there was any documentation about the differences between the rev 0 and rev A, but I can't seem to find anything.
8 Bit Dreams
- Moderator Team
Nope, 020 CPU is cold as women's feets, there must be something elseterriblefire wrote: 13 Mar 2019 22:27
