TT Boot Logo
Atarian Computing
TT Boot Logo
So I was bored today and had a go at making a custom boot logo. Pretty happy with it.
Credit for this particular Fuji and Atari pixelart goes to junosix over at http://atari-forum.com/viewtopic.php?f= ... 2&#p297310
Re: TT Boot Logo
:coolpics:Atarian Computing wrote: 10 Mar 2019 08:22 So I was bored today and had a go at making a custom boot logo. Pretty happy with it.
Very bohemian rhapsody :)
Would be great if you could do a guide on this Atari Computing.
Atarian Computing
Re: TT Boot Logo
Thanks. It was pretty easy to figure out in the end.
The offset where the logo begins in TOS3.06 is 35FF4
The logo image is 96px wide and I assumed 96px high but my first attempt was cropped. So not sure of exact height.
Starting from offset 35FF4, each HEX value represents 8 pixels in binary.
00 is no pixels - ........
FF is 8 pixels - XXXXXXXX
My logo's first three bytes are 00 7F C0. In binary (and pixels in this case) it would be .........XXXXXXXXX...... with dots being zero and X's being ones.
Here's the hexcode for my logo:
And here's a binary representation of that with dots and X's.
You can just create a bitmap and use any of the many converters, like http://dot2pic.com
https://www.asciitohex.com is best to convert between binary and hex.
00 7f c0 00 00 00 00 00 00 00 00 00 00 c0 20 00 00 00 00 00 00 00 00 00 00 a0 fe 01 d0 00 40 0c 80 00 00 04 00 c1 81 00 99 58 cd 89 cd bc 0d 8c 00 a1 41 00 95 55 51 04 95 2a 15 54 0f 01 81 00 94 d4 cd 4c 99 2a 8d 4c 18 0e 00 c0 00 00 00 40 00 00 80 00 14 18 00 20 00 00 00 00 00 00 00 00 18 14 00 24 41 08 10 00 00 00 00 00 14 18 00 24 0d 9d 86 30 29 b5 29 b5 1a 0c 00 24 55 49 55 53 2a 25 2a 25 1f ff ff c7 4d 49 55 30 11 a3 11 a3 0f ff fc 00 04 00 00 10 00 01 00 01 00 00 00 00 08 00 00 20 00 02 00 02 01 03 e0 00 00 00 00 00 00 00 00 00 02 27 82 40 00 84 10 80 10 00 00 00 04 4e 04 80 01 30 d9 cd 86 33 c6 00 08 9f c9 00 03 a5 54 91 55 52 a8 00 01 01 92 00 01 24 d4 8d 55 32 a6 00 02 23 24 00 00 00 40 00 00 10 00 00 04 42 48 80 00 00 80 00 00 20 00 00 08 84 81 00 00 00 00 00 00 00 00 00 00 08 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 37 60 00 01 01 ff e0 20 00 f8 0f 00 37 60 00 03 81 ff e0 70 03 fe 0f 00 37 60 00 07 c1 ff e0 f8 07 ff 0f 00 37 60 00 07 c1 ff e0 f8 07 ff 8f 00 37 60 00 0f e0 1e 01 fc 07 87 cf 00 37 60 00 0f e0 1e 01 fc 07 83 cf 00 37 60 00 0f e0 1e 01 fc 07 83 cf 00 37 60 00 1e f0 1e 03 de 07 83 cf 00 37 60 00 1e f0 1e 03 de 07 83 cf 00 77 70 00 1e f0 1e 03 de 07 87 cf 00 77 70 00 3c 78 1e 07 8f 07 8f 8f 00 f7 78 00 3c 78 1e 07 8f 07 9f 0f 00 f7 78 00 7c 7c 1e 0f 8f 87 be 0f 01 e7 3c 00 7f fc 1e 0f ff 87 bc 0f 01 e7 3c 00 7f fc 1e 0f ff 87 bc 0f 03 c7 1e 00 ff fe 1e 1f ff c7 be 0f 07 c7 1f 00 ff fe 1e 1f ff c7 9f 0f 0f 87 0f 80 f0 1e 1e 1e 03 c7 8f 8f 3f 07 07 e1 f0 1f 1e 3e 03 e7 87 cf fe 07 03 f9 e0 0f 1e 3c 01 e7 83 cf f8 07 00 fb e0 0f 9e 7c 01 f7 81 cf e0 07 00 3b c0 07 9e 78 00 f7 80 cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 3f c3 c1 f0 3c 00 00 00 00 00 00 ff 3f c7 e1 f8 7e 00 00 00 00 00 00 18 06 0e 70 18 e7 00 00 00 00 00 00 18 06 0c 30 f8 c3 00 00 00 00 00 00 18 06 0c 30 fc c3 00 00 00 00 00 00 18 06 0c 30 0c c3 00 00 00 00 00 00 18 06 0e 70 0c e7 00 00 00 00 00 00 18 06 07 e1 fc 7e 00 00 00 00 00 00 18 06 03 c1 f8 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0c fc c7 8c 63 33 8e 39 e4 5f 51 38 1e fd e7 cc f3 34 51 55 14 44 51 44 33 33 36 6d 9b 34 11 55 14 44 59 40 33 33 36 6d 9b b4 11 55 14 44 5d 40 3f 33 f7 cd fb f4 11 55 e4 44 57 4c 3f 33 f7 ed fb 74 11 55 04 44 53 44 33 33 36 6d 9b 34 51 55 04 44 51 44 33 33 36 6d 9b 33 8e 45 03 84 51 3c Code: Select all
.........XXXXXXXXX..............................................................................
........XX........X.............................................................................
........X.X.....XXXXXXX........XXX.X.............X..........XX..X............................X..
........XX.....XX......X........X..XX..X.X.XX...XX..XX.XX...X..XXX..XX.XX.XXXX......XX.XX...XX..
........X.X....X.X.....X........X..X.X.X.X.X.X.X.X.X...X.....X..X..X.X.X..X.X.X....X.X.X.X.X.X..
....XXXX.......XX......X........X..X.X..XX.X.X..XX..XX.X.X..XX..X..XX..X..X.X.X.X...XX.X.X..XX..
...XX.......XXX.........XX...............................X......................X...............
...X.X.....XX.............X.....................................................................
...XX......X.X............X..X...X.....X....X......X............................................
...X.X.....XX.............X..X......XX.XX..XXX.XX....XX...XX......X.X..XX.XX.X.X..X.X..XX.XX.X.X
...XX.X.....XX............X..X...X.X.X.X.X..X..X.X.X.X.X.X.X..XX..X.X.X...X..X.X..X.X.X...X..X.X
...XXXXXXXXXXXXXXXXXXXXXXX...XXX.X..XX.X.X..X..X.X.X.X.X..XX.......X...XX.X...XX...X...XX.X...XX
....XXXXXXXXXXXXXXXXXX...............X.....................X...................X...............X
....................................X.....................X...................X...............X.
.......X......XXXXX.............................................................................
......X...X..XXXX.....X..X..............X....X.....X....X..........X............................
.....X...X..XXX......X..X..............X..XX....XX.XX..XXX..XX.XX....XX...XX..XXXX...XX.........
....X...X..XXXXXXX..X..X..............XXX.X..X.X.X.X.X..X..X...X.X.X.X.X.X.X..X.X.X.X...........
.......X.......XX..X..X................X..X..X..XX.X.X..X...XX.X.X.X.X.X..XX..X.X.X..XX.........
......X...X...XX..X..X...........................X.........................X....................
.....X...X....X..X..X...X.......................X.........................X.....................
....X...X....X..X......X........................................................................
............X.........X.........................................................................
..........XX.XXX.XX....................X.......XXXXXXXXXXXX.......X.............XXXXX.......XXXX
..........XX.XXX.XX...................XXX......XXXXXXXXXXXX......XXX..........XXXXXXXXX.....XXXX
..........XX.XXX.XX..................XXXXX.....XXXXXXXXXXXX.....XXXXX........XXXXXXXXXXX....XXXX
..........XX.XXX.XX..................XXXXX.....XXXXXXXXXXXX.....XXXXX........XXXXXXXXXXXX...XXXX
..........XX.XXX.XX.................XXXXXXX........XXXX........XXXXXXX.......XXXX....XXXXX..XXXX
..........XX.XXX.XX.................XXXXXXX........XXXX........XXXXXXX.......XXXX.....XXXX..XXXX
..........XX.XXX.XX................XXXX.XXXX.......XXXX.......XXXX.XXXX......XXXX.....XXXX..XXXX
.........XXX.XXX.XXX...............XXXX.XXXX.......XXXX.......XXXX.XXXX......XXXX....XXXXX..XXXX
.........XXX.XXX.XXX..............XXXX...XXXX......XXXX......XXXX...XXXX.....XXXX...XXXXX...XXXX
........XXXX.XXX.XXXX.............XXXX...XXXX......XXXX......XXXX...XXXX.....XXXX..XXXXX....XXXX
........XXXX.XXX.XXXX............XXXXX...XXXXX.....XXXX.....XXXXX...XXXXX....XXXX.XXXXX.....XXXX
.......XXXX..XXX..XXXX...........XXXXXXXXXXXXX.....XXXX.....XXXXXXXXXXXXX....XXXX.XXXX......XXXX
......XXXX...XXX...XXXX.........XXXXXXXXXXXXXXX....XXXX....XXXXXXXXXXXXXXX...XXXX.XXXXX.....XXXX
.....XXXXX...XXX...XXXXX........XXXXXXXXXXXXXXX....XXXX....XXXXXXXXXXXXXXX...XXXX..XXXXX....XXXX
....XXXXX....XXX....XXXXX.......XXXX.......XXXX....XXXX....XXXX.......XXXX...XXXX...XXXXX...XXXX
..XXXXXX.....XXX.....XXXXXX....XXXXX.......XXXXX...XXXX...XXXXX.......XXXXX..XXXX....XXXXX..XXXX
XXXXXXX......XXX......XXXXXXX..XXXX.........XXXX...XXXX...XXXX.........XXXX..XXXX.....XXXX..XXXX
XXXXX........XXX........XXXXX.XXXXX.........XXXXX..XXXX..XXXXX.........XXXXX.XXXX......XXX..XXXX
XXX..........XXX..........XXX.XXXX...........XXXX..XXXX..XXXX...........XXXX.XXXX.......XX..XXXX
........................XXXXXXXX..XXXXXXXX....XXXX.....XXXXX......XXXX..........................
........................XXXXXXXX..XXXXXXXX...XXXXXX....XXXXXX....XXXXXX.........................
...........................XX........XX.....XXX..XXX.......XX...XXX..XXX........................
...........................XX........XX.....XX....XX....XXXXX...XX....XX........................
...........................XX........XX.....XX....XX....XXXXXX..XX....XX........................
...........................XX........XX.....XX....XX........XX..XX....XX........................
...........................XX........XX.....XXX..XXX........XX..XXX..XXX........................
...........................XX........XX......XXXXXX....XXXXXXX...XXXXXX.........................
...........................XX........XX.......XXXX.....XXXXXX.....XXXX..........................
....XX..XXXXXX..XX...XXXX...XX...XX...XX..XX..XXX...XXX...XXX..XXXX..X...X.XXXXX.X.X...X..XXX...
...XXXX.XXXXXX.XXXX..XXXXX..XX..XXXX..XX..XX.X...X.X...X.X.X.X.X...X.X...X...X...X.X...X.X...X..
..XX..XX..XX..XX..XX.XX..XX.XX.XX..XX.XX..XX.X.....X...X.X.X.X.X...X.X...X...X...X.XX..X.X......
..XX..XX..XX..XX..XX.XX..XX.XX.XX..XX.XXX.XX.X.....X...X.X.X.X.X...X.X...X...X...X.XXX.X.X......
..XXXXXX..XX..XXXXXX.XXXXX..XX.XXXXXX.XXXXXX.X.....X...X.X.X.X.XXXX..X...X...X...X.X.XXX.X..XX..
..XXXXXX..XX..XXXXXX.XXXXXX.XX.XXXXXX.XX.XXX.X.....X...X.X.X.X.X.....X...X...X...X.X..XX.X...X..
..XX..XX..XX..XX..XX.XX..XX.XX.XX..XX.XX..XX.X...X.X...X.X.X.X.X.....X...X...X...X.X...X.X...X..
..XX..XX..XX..XX..XX.XX..XX.XX.XX..XX.XX..XX..XXX...XXX..X...X.X......XXX....X...X.X...X..XXXX..https://www.asciitohex.com is best to convert between binary and hex.
Re: TT Boot Logo
Nice one!
dhedberg
Re: TT Boot Logo
Haha. I love it!
Daniel, New Beat - http://newbeat.atari.org.
Like demos? Have a look at our new Falcon030 demo It's that time of the year again, or click here to feel the JOY.
DrF
Re: TT Boot Logo
That is some really out there thinking, how awesome :D
Atarian Computing
Re: TT Boot Logo
Thanks guys :)
Working great now with UK keytable on TS roms. CRC fixed too, of course.
pakman
Re: TT Boot Logo
Height is 86 pixels.Atarian Computing wrote: 10 Mar 2019 09:03 The logo image is 96px wide and I assumed 96px high but my first attempt was cropped. So not sure of exact height.
Bigger logos are also possible. I remember I was using a logo more than 96 pixels wide.. long time ago..
Atarian Computing
Re: TT Boot Logo
Good info, thanks!pakman wrote: 12 Mar 2019 19:28Height is 86 pixels.Atarian Computing wrote: 10 Mar 2019 09:03 The logo image is 96px wide and I assumed 96px high but my first attempt was cropped. So not sure of exact height.
frank.lukas
Re: TT Boot Logo
Can someone build a patcher Program to change the boot Logo from TOS 2.06 and TOS 3.06 ?
Back in these days there was such a program from Rainer Rosin but I can not find it ...
