kludge’s TF530 build
TF530 - 63030 + RAM Board
kludge
Re: kludge’s TF530 build
Post by kludge »
Better (desoldered and resoldered the oscillator). Still no output on CLKOUT though. Tried just hooking up 3.3V to the input and the output did respond. Didn’t connect it through a 10k resistor, though.
Might just have to order some new buffers to make sure I have the right components.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
kludge
Post by kludge »
My bad. I DO have some output on CLKOUT. Weird-ass output.
For comparison; here's CLKOUT when JP1 is set to the 7 MHz clock:
My lack of focus:
redhawk668
Post by redhawk668 »
I had the same problem with my TF530, it wouldn’t boot. No clock signal. Turned out to be a short on the BUS CPLD. I reflowed it and my Amiga booted with the TF530 at 50 mhz.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
kludge
Post by kludge »
redhawk668 wrote: 07 Mar 2019 20:01 I had the same problem with my TF530, it wouldn’t boot. No clock signal. Turned out to be a short on the BUS CPLD. I reflowed it and my Amiga booted with the TF530 at 50 mhz.
But then I wouldn’t get a clock signal when the jumper is set to 7 MHz either, right?
My lack of focus:
The clock topology was one of the major reasons for the TF534.
kludge
Post by kludge »
terriblefire wrote: 07 Mar 2019 21:18 The clock topology was one of the major reasons for the TF534.
But I’m damn sure I want this to run! Will I damage the 3.3V stuff if I hook up a 5V oscillator instead? I was thinking if I could use the signal from the 28 MHz one from the Amiga to check if everything else is working.
My lack of focus:
nothing will get damaged by a 5V osc... but you will make the reflection problem worse
kludge
Post by kludge »
terriblefire wrote: 07 Mar 2019 22:09 nothing will get damaged by a 5V osc... but you will make the reflection problem worse
Ah. Would it be possible to add some kind of termination on the signal if that is the case? I don’t mind dead bug-ing the hell out of this board. I am kludge, after all ;)
Come to think of it, I have a pile of 50 MHz 5V oscillators that I ordered by mistake. But 50 MHz AND 5V might be pushing it.
My lack of focus:
Maximilian
Post by Maximilian »
The 10K resistor was there to not damage anything as you do not know where te problem is.
Please leave the A500 oscillator alone, you are only getting further down the rabbit hole.
P.s. witch 68030 did you get? 33c? , that could probably run on 50Mhz...., just remove the coprocessor if it is slower than 50Mhz
If you have to wait for parts i have an Idea... :twisted:
1. Take the 50Mhz 5v Oscillator and test it on 3v, if it runs you are in luck and you can use it on 3,3v.
2. Put the above on a piece of perfboard with frequency divider using a d-flip flop on 3,3v , and then you have 25Mhz.
(don't forget a 19Uf cap across VCC and GND)
3. Test
4. Put on your new Oscillator on when it arrives.
kludge wrote: 07 Mar 2019 22:12
There is a resistor pad in the Rev 3 for this purpose. North of the RaM cpld next to the SPI port.
I’d also recommend putting the FPU in if you haven’t already. It has the same effect
Return to “TF530”
