Something's wrong with that one, the archive is empty.terriblefire wrote: Mon Feb 18, 2019 8:57 am Did you grab the firmware I stuck in the repo over the weekend?
Latest TF534 is here
Re: Latest TF534 is here
- Admin sponsor
Will sort later... mad busy with kids so might have missed something
- Admin sponsor
Ok new firmware pushed.. Its a combined pack for all boards.
https://github.com/terriblefire/terribl ... _alpha.zip
- Admin sponsor
@alenppc i noticed a regression with my IDE code on the TF534... must have been when i was trying to figure out my cable issues. I've emailed you a new version. Let me know how you get on and i'll push to the repo.
Spotted a small bug on the 534 rev2c, the only one so far.
- Admin sponsor
What’s the bug.. difficult to tell from the screenshot
The Early Startup Menu pretty much crashes the machine (the buttons are not displayed) and crash if you click in their place.
This is at 36 MHz. I have not encountered any other issues so far.
- Admin sponsor
I’ve seen this before. Thought it was cache related. :/
I don't think this is cache, it's something else. I don't think 2b had it, but I can double check.
- Admin sponsor
There are no changes between the two that could account for this. Very odd..
EDIT: Sum total of changes are a pull up on BG20, rewired 5 missing address pins to the unused pins on the RAMCPLD and I removed an earth trace that was on the bottom layer so that I could give more space to grounding to the ground plane.
This can’t account for a major behaviour change.
