Latest TF534 is here
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
go0se
Re: Latest TF534 is here
Post by go0se »
terriblefire wrote: 23 Jan 2019 09:10 Not sure. Doesn’t manage to read the first 4 words in rom correctly. So might be a solder issue
As a great man once said : "Clocks are the biggest problem for a non booting Diagrom, or just bad soldering."
S.J Leary, Youtube, December 2017 :)
This usually applies to board that has booted at least once... no such luck here.
ok it boots to DiagROM. Bad firmware was the issue.
kludge
Post by kludge »
terriblefire wrote: 24 Jan 2019 12:17 ok it boots to DiagROM. Bad firmware was the issue.
Great stuff! Looking forward to the next live stream!
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
Homer79
Post by Homer79 »
If you want a fan holder, how about something like this? maybe locate the holes with maximum clearances available
if its too tall then maybe a 5015 blower fan off to the side
https://www.ebay.co.uk/itm/2Pcs-38mm-x- ... ctupt=true
https://www.ebay.co.uk/itm/5V-DuPont-35 ... ctupt=true
Thanks. Is there any clamps that are suitable available off the shelf? I just try to make it easy whereever i can.
Also I broke the TF534.. well the IDE... no idea what i did.
kludge
Post by kludge »
terriblefire wrote: 24 Jan 2019 22:15 Also I broke the TF534.. well the IDE... no idea what i did.
You mean that you have no IDEa? Sorry.
My lack of focus:
MarkFixesStuff
Post by MarkFixesStuff »
kludge wrote: 24 Jan 2019 22:59 You mean that you have no IDEa? Sorry.
:bravo: :lol:
It's me. Mark from Mark Fixes Stuff on the YouTube thingymajig.
https://www.youtube.com/markfixesstuff - I know... It's patently obvious I don't have a clue! :P
So it turns out that the problem was a duff IDE cable. Probably caused by me using it as a jig while soldering.
kludge
Post by kludge »
So... It sounds like this will be released soon-ish. If I wanded to begin the hunt for components for the TF534; what are the specs for the CPLDs and RAM?
My lack of focus:
Return to “TF534 (OBSOLETE)”
