Latest TF534 is here
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
go0se
Re: Latest TF534 is here
Post by go0se »
Excellent! Cheers.
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
just want to add one important detail Steve forgot to mention - TF534 card doesn't need INT2 and OVR interrupt signals anymore,
so this card is Plug'n'Play
8 Bit Dreams wrote: 19 Jan 2019 17:01 just want to add one important detail Steve forgot to mention - TF534 card doesn't need INT2 and OVR interrupt signals anymore,
Indeed thanks for mentioning that. Thats always my goal... make it as easy to use as possible.
Few more points to mention...
The TF534 IDE interface is working with EmuTOS IDE out of the box. No drivers etc needed.. Just works. Therefore this is the "TOS" I recommend.
I'm open to suggestions where the fastram should live on an ST. If a patched TOS3.06 were used it would be nice if the ram were located somewhere that it could take advantage of this optimally.
The latest board has an extra pull up that should help Floppy compatibility.
It may be possible to get ROMs running slowly out of the Serial EEPROM.. By slowly i mean probably ~500ns per access. This was my intention for ROMs rather than having an external board. Having a £2 SOIC8 chip on the board that has ROMs would be perfect in terms of space and cost.
I would really like to port "CPU FASTROM" to the Atari ST at some point. The biggest issue i see with this is that the jump vector at address 0 would need to be patched too. If this worked the ROM could be moved to fastram and MMU mapped. The results on the Amiga are spectacular.
redhawk668
Post by redhawk668 »
Awesome! As soon as they are available, I will get one and the needed parts and solder it up.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
I finished building tonight except for the 68000 socket.. I plan to bring up the badger tomorrow night.
MarkFixesStuff
Post by MarkFixesStuff »
It's... so... beautiful!
:yay:
It's me. Mark from Mark Fixes Stuff on the YouTube thingymajig.
https://www.youtube.com/markfixesstuff - I know... It's patently obvious I don't have a clue! :P
Ok. Doesn’t appear to work. Not even DiagROM. Will investigate a bit but TBH I may scrap the TF534 at this point.
kludge
Post by kludge »
terriblefire wrote: 23 Jan 2019 08:01 Ok. Doesn’t appear to work. Not even DiagROM. Will investigate a bit but TBH I may scrap the TF534 at this point.
Crap. That’s unfortunate. Any ideas on what went wrong?
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
Not sure. Doesn’t manage to read the first 4 words in rom correctly. So might be a solder issue
Return to “TF534 (OBSOLETE)”
