Project: HDMI/DVI out for STFM
Progress on our FPGA cores.
ijor
Post by ijor »
czietz wrote: 04 Dec 2018 17:51But iirc Smonson made a test program that generates a trigger signal upon faulty reads. Wouldn't the best way forward be to use that test program and to probe (with a scope) e.g. D9 at every buffer, level shifter or latch it passes through. Somewhere it must get corrupted.
Note that it doesn't exactly seem that D9 is corrupted. It seems that at least on some cycles, the bus (the local Shifter-RAM bus) is not driven at all. If this is true, this could only happen at the level shifter or possibly at the FPGA itself.
Probing D9 at the FPGA side on a "bad" read might be interesting. But unless the scope can probe two signals and trigger on a third one, then it might be difficult to match the D9 signal with the Shifter access.
http://pasti.fxatari.com
ijor
Post by ijor »
Gunstick wrote: 04 Dec 2018 23:50Oh, if I knew which STs have an IMP. Looks like I'll need to open them all up.
Well, you can try Closure and Aliens' 4-bit sync scroll. If both work then probably it is a "common" 38-A Shifter.
Well the one problem-ST I have currently open only has one IMP chip: C070714-001 (GLUE) and on that one neither closure nor DSOTS run.
Interesting. I think that this is not an officially supported setup. Other people here might know better, but I think Atari never shipped a computer with just an IMP GLUE alone. And actually there are some Atari notes warning about mixing IMP and older chips. Probably some combinations are safer than others though.
You didn't specify how you are reading the bus capacitance. If you are just reading from unpopulated RAM space, then this doesn't depend on Shifter at all.
czietz
Post by czietz »
ijor wrote: 05 Dec 2018 01:28 Probing D9 at the FPGA side on a "bad" read might be interesting. But unless the scope can probe two signals and trigger on a third one, then it might be difficult to match the D9 signal with the Shifter access.
That's why (in an earlier post) I wrote to connect the trigger signal of the test program to the external trigger input of the scope, which leaves the two channels for probing signals.
Smonson
Post by Smonson »
ijor wrote: 05 Dec 2018 01:28 Note that it doesn't exactly seem that D9 is corrupted. It seems that at least on some cycles, the bus (the local Shifter-RAM bus) is not driven at all. If this is true, this could only happen at the level shifter or possibly at the FPGA itself.
The last test config file I've prepared should be able to indicate which of these two scenarios are occurring.
czietz wrote: 04 Dec 2018 17:51 Sorry, I missed a lot of posts in this thread the last few days. But iirc Smonson made a test program that generates a trigger signal upon faulty reads. Wouldn't the best way forward be to use that test program and to probe (with a scope) e.g. D9 at every buffer, level shifter or latch it passes through. Somewhere it must get corrupted. Then look at the direction and/or output enable signal of the IC where D9 is not passed through correctly.
Yes, it only remains for a generous person to have time to do this test, which is another in a series of tests that has been very time-consuming for those volunteers so far. Let's not rush them :)
ijor
Post by ijor »
Smonson wrote: 05 Dec 2018 08:45 The last test config file I've prepared should be able to indicate which of these two scenarios are occurring.
I was thinking ... for a change :) ...
I would like to see good scope dumps of both F_DIR and D9 at the FPGA side, both on a "bad" cycle, both on a failing system of course. May be F_DIR is not reaching a voltage high enough for the transceiver to change direction. This might depend a lot on the specific system, and then it might explain why the same board works on one system but not on the other.
Note that in turns this might have damaged the FPGA ports because failing to change direction would create bus contention. Specially when it was tested without the resistors.
But I have a feeling that eventually we won't have much choices but to follow Exxos idea of shipping a failing system to Smonson. I agree with Troed that we don't know if this is related to motherboard revision. So it has to be a full system including at least motherboard and HDMI board, that was tested to fail. If shipping cost is the problem may be we can all share the cost. I wouldn't mind to contribute.
I've made a suggestion to icky, that once he's done tests, to loan me his HDMI board to test in my machine..
But so far, It seems like its only failing in stm machines?
troed
Post by troed »
exxos wrote: 05 Dec 2018 11:40 But so far, It seems like its only failing in stm machines?
520 STM and 1040 STFM (SMT rev) here. It's on my todo to run it on a 1040 STF (red led old model) and a few Mega STs. I'm really sorry for not being able to allocate more time to it atm ...
/Troed
One thing I'm not following, is if there is a drive problem on D9, why would it work on some boards but not others?
I don't know about FPGA , but on pld chips they have input only pins which can catch you out sometimes.
Smonson
Post by Smonson »
troed wrote: 05 Dec 2018 11:44 I'm really sorry for not being able to allocate more time to it atm ...
Don't be, it's awesome that you've already done so much to help.
exxos wrote: 05 Dec 2018 12:37 One thing I'm not following, is if there is a drive problem on D9, why would it work on some boards but not others?
Just another piece in the puzzle. What I know is, none of the boards I've made (maybe 8 or 9) have exhibited this behaviour on my machine (I tested them all); and of the 4 that have been tried by other people so far, 3 of them have developed the resetting problem after being installed into their new home. And in Troed's case that has happened twice in a row. So it seems to be ST specific behaviour and not mod board specific - so far.
Hmm, incidentally, Exxos are you running a stock power supply in your test machine? I have a stock PSU, I think Troed has a modern replacement. My 5v level is actually about 4.7v. Dunno if it could be connected but couldn't hurt to rule it out...
troed
Post by troed »
Smonson wrote: 05 Dec 2018 13:07 Hmm, incidentally, Exxos are you running a stock power supply in your test machine? I have a stock PSU, I think Troed has a modern replacement. My 5v level is actually about 4.7v. Dunno if it could be connected but couldn't hurt to rule it out...
My 520STM runs off a picoPSU and the 1040STFM off a recapped original PSU - at 5.1V or so (helps with the overclocking). It's an SR98 so I can always lower it.
Return to “FPGA DEVELOPMENT”
