They fleece you everywhere nowadays.exxos wrote: Fri Oct 30, 2026 7:56 am Its always to much. They expensive parts to buy these days. But they also charge on shipping as well.. Really sucks![]()
- HigashiJun
It seems after some weeks now that Evri have lost the new videl.
So likely won't be any progress until next year now
How on earth did Evri get hold of the package... it's coming from USA right? I thought it'd be professional courier and/or royal mail.exxos wrote: Sun Nov 29, 2026 11:36 am It seems after some weeks now that Evri have lost the new videl.So likely won't be any progress until next year now
Because the customer ordered it to his home address. I requested that as I didn't want to be involved with any potential shipping drama and paying taxes etc. Once it was in the uk, it was shipped to me by Evri.Steve wrote: Sun Nov 29, 2026 11:49 am How on earth did Evri get hold of the package... it's coming from USA right?
Gotta love the irony of it all I suppose..
Can't believe he chose Evri for such an important thing ..... I'd have done royal mail 1st class signed for.exxos wrote: Sun Nov 29, 2026 11:55 amBecause the customer ordered it to his home address. I requested that as I didn't want to be involved with any potential shipping drama and paying taxes etc. Once it was in the uk, it was shipped to me by Evri.Steve wrote: Sun Nov 29, 2026 11:49 am How on earth did Evri get hold of the package... it's coming from USA right?
Apparently it was insured though. But likely he will have to order again.Steve wrote: Sun Nov 29, 2026 3:22 pm Can't believe he chose Evri for such an important thing ..... I'd have done royal mail 1st class signed for.
I made a small re-design of my CT60PSU, I duplicated Centuriontech's PCB but added an opto-coupler to only have mains in the rocker switch. Seems to work fine, 030/060 switching works and IMHO it feels a lot safer. I'm not advising anyone else to do the same, since this is mains voltage stuff and of course can be very dangerous (destroy your Falcon or worse, burn down your house), but anyway thought I'd share in case anyone is interested.
Circuit looks like this: And the PCB and re-assembled CT60PSU looks like this: I tried sending a mail to Pavel to suggest a similar re-design of the CT60PSU's he sells since it's a very minor change, but no response yet.
Nice work, the opto is definitely a step in the right direction, as at least the mode signal is now isolated from the mains side.
I have a question on the schematic though. Pins 4 and 6 on SW1 both seem to go to L, so unless I am misreading it, pin 5 outputs L in either position and that pole never actually switches anything. Is that how it is wired on the board, or is the schematic not quite matching? If it is as drawn, the mode would be changing with the machine still powered up, and I would be wary of what the CT60 does with a live mode change.
The other pole is still switching live mains, now through the 300k into the opto LED, so the switch is still a mains component. The thing I am still not keen on is using a mains switch to change modes in the first place. That is the part I think is the real problem with the original design, and the opto does not really change that.
Each 100k resistor also sees roughly 77V rms in normal running, before any mains spikes, so I would check the resistor size and voltage rating are up to it.
The bigger concern for me is the layout. From the photo, the three series resistors look very close to whatever tracks they are running past. With mains, that really needs a slot in the PCB. If mains flashes over to the resistor chain, it can blow the opto, and the opto output goes straight to the Falcon. Anywhere mains comes near low voltage, it needs proper separation with an air gap, not just a bit of FR4 and solder mask, especially if the board ever picks up moisture or dust.
