Sun Ultrasparc
Show us your vintage gear. Be it audio hardware repair, handheld / board electronic games, to synth restoration. Start your own blog etc
Re: Sun Ultrasparc
Hot air is your friend when trying to get that epoxy potting off. It crumbles if heated to ~200C.
Oldskool
Re: Sun Ultrasparc
Post by Oldskool »
Ok yes I saw that indeed but I don't have a hot air station but I assume the correct metal pins are now exposed for receiving a wire. So a knife also works.
Re: Sun Ultrasparc
I'm just experimenting with roasting the chip in the oven as an alternative.
Oldskool
Re: Sun Ultrasparc
Post by Oldskool »
Short update. Bought some fans to replace the old ones. The bearing in the original fans are gone. They are based on a piece of foam which is powder now..
Case fan + cpu:
Oldskool
Re: Sun Ultrasparc
Post by Oldskool »
So my local electronic part shop stopped so I need to order everything now😭
Finally Recieved the battery holder. But indeed this fixed the nvram issue.
Next step reinstall videocard and test video out..
Return to “VINTAGE GEAR ZONE”
