Sun Ultrasparc
Re: Sun Ultrasparc
The power LED is software controlled. It won't turn on without the CPU telling it to.
If you had a keyboard it would be using the LEDs to show how the POST is progressing.
Re: Sun Ultrasparc
To satisfy my Sun workstation craving I accepted a freebie from work 26 years ago. It's been under the bed in the front room almost all this time. They had lots of different models up for grabs. I went with the Sun Ultra 5 as unlike older models it's practically a PC but with an Ultra SPARC processor. It has IDE for HDD & CDROM, 31Khz VGA output, standard PCI slots and standard DRAM slots.
https://en.wikipedia.org/wiki/Ultra_5/10
Re: Sun Ultrasparc
I'm also in the Sun club, I have an Ultra 60 with 2 x 360mhz CPUs, XVR-600 graphics, 2GB RAM, gigabit ethernet and USB.
Re: Sun Ultrasparc
Nice to see all the Sun computer peoplestephen_usher wrote: Mon Nov 02, 2026 11:41 pm The power LED is software controlled. It won't turn on without the CPU telling it to.
Very Sunny indeed.
So tried with keyboard connected. The on/off switch on the keyboard turns on the main unit.
The keyboard beeps one time.
The light on the keys come on for a second and turn off. The caps lock starts blinking and then stays on. After a couple of seconds the front led blinks ones and after that the caps lock turns off. I can’t turn the system off with the keyboard. I assume the computer is in a sort of fail safe mode. As there is no videocard or serial connection. And the nvram is probably dead.
No new front light blink codes
Now need to wait for the cables.
Re: Sun Ultrasparc
With no valid NVRAM settings it will drop into diagnostic mode and spend a good few minutes doing the diagnostics and then try to do a network boot.
- HigashiJun
Re: Sun Ultrasparc
This thread makes me want to buy a SUN4/50 SparcStation IPX.
I can have one for a good price, but without a keyboard though...
Re: Sun Ultrasparc
I do love Sun equipment.
I first had a Sparcstation 20 that someone gave me. Picking that up was like going to the gym.
Next was an Ultra 1, like you have, Ultra 5,10 and a few others. I've got an Ultra 24 at the mo, some would say not a proper Sun computer but I wanted something more "useful" from my point of view.
They are great machine, everything is easy to work on and we'll built.
Enjoy your Ultra 1.
Enjoy your Ultra 1.
Re: Sun Ultrasparc
So good news!!
Finally received the rs232 cable and output via serial works.
I tried a new NVram but that also seems dead. So need to do some cutting I think.
This is the output from serial:
@(#) Sun Ultra 1 UPA/SBus 3.0 Version 4 created 1995/11/26 17:57
Clearing E$ Tags Done
Clearing I/D TLBs Done
Probing Memory Done
MEM BASE = 0000.0000.1000.0000
MEM SIZE = 0000.0000.0800.0000
MMUs ON
Copy Done
PC = 0000.01ff.f000.1a7c
PC = 0000.0000.0000.1ac0
Decompressing into Memory Done
Size = 0000.0000.0007.00b0
ttya initialized
SC Control: EWP:0 IAP:0 FATAL:0 WAKEUP:0 BXIR:0 BPOR:0 SXIR:0 SPOR:1 POR:0
Probing Memory Bank #0 32 + 32 : 64 Megabytes
Probing Memory Bank #1 64 + 64 : 128 Megabytes
Probing Memory Bank #2 0 + 0 : 0 Megabytes
Probing Memory Bank #3 0 + 0 : 0 Megabytes
Probing UPA Slot at 1e,0 Nothing there
Probing /sbus@1f,0 at 0,0 Nothing there
Probing /sbus@1f,0 at 1,0 Nothing there
screen not found.
Can't open input device.
Keyboard not present. Using ttya for input and output.
Sun Ultra 1 UPA/SBus (UltraSPARC 167MHz), No Keyboard
OpenBoot 3.0, 192 MB memory installed, Serial #16777199.
Ethernet address ff:ff:ff:ef:ff:ff, Host ID: ffffffef.
The IDPROM contents are invalid
Boot device: net File and args:
Internal loopback test -- Did not receive expected loopback packet.
Evaluating: boot
Can't open boot device
ok
Re: Sun Ultrasparc
That all looks good to me!
Re: Sun Ultrasparc
Thanks for the feedback. I did done cutting on the original nvram. I assume these are the contact points for connecting a battery.
