Got struck with an idea while driving home from work and had to try it..
It's not a crazy performance bump, but for only a few lines of code it's not a bad free performance boost.
For now only applied on the SVGA driver but I should be able to make this global so it effects ET4000 and Mach as well.
There are further optimisations which could be made in the same spirit but requires more work.
Cirrus GD5434 now vs previous driver:
@agranlund that's a pretty good increase for just a few lines of code.
Yep, I realised if I tag the vram pages as cache-inhibited-imprecise to take advantage of the storebuffer fifo then the cpu can keep doing a little bit of meaningful work while an ISA transfer is happening.PhilC wrote: Mon Oct 05, 2026 8:30 pm @agranlund that's a pretty good increase for just a few lines of code.
I wish I had room in my brain for stuff like that, let alone coming up with the idea whilst driving homeagranlund wrote: Tue Oct 06, 2026 10:47 pmYep, I realised if I tag the vram pages as cache-inhibited-imprecise to take advantage of the storebuffer fifo then the cpu can keep doing a little bit of meaningful work while an ISA transfer is happening.PhilC wrote: Mon Oct 05, 2026 8:30 pm @agranlund that's a pretty good increase for just a few lines of code.
You could have asked me, I did the same for CTPCI and SuperVidel years ago.agranlund wrote: Tue Oct 06, 2026 10:47 pm Yep, I realised if I tag the vram pages as cache-inhibited-imprecise to take advantage of the storebuffer fifo then the cpu can keep doing a little bit of meaningful work while an ISA transfer is happening.
Actually, yes! It's hard to ask about what you don't know but yes, it makes sense you did the same for those way back thenmikro wrote: Wed Oct 07, 2026 11:25 amYou could have asked me, I did the same for CTPCI and SuperVidel years ago.agranlund wrote: Tue Oct 06, 2026 10:47 pm Yep, I realised if I tag the vram pages as cache-inhibited-imprecise to take advantage of the storebuffer fifo then the cpu can keep doing a little bit of meaningful work while an ISA transfer is happening.![]()
Probably worth me having a look at more of those sources in case there are other nice tidbits to learn from.
Or if you still have some ancient knowledge of other clever things that was done for CT60/PCI/SV that I could benefit from.
Fair point.agranlund wrote: Wed Oct 07, 2026 8:57 pmIt's hard to ask about what you don't know but yes, it makes sense you did the same for those way back then
Actually, there is nothing to look at. I had a conversation with the Nature brothers back in 2014 where they mentioned that they are disabling cache for the whole SV memory area. I looked into 68060 UM how it's done and discovered that there are two models, precise and imprecise. So I just tried to change the PMMU to mark them as imprecise and voila. However the precise model has its use (naturally), for instance for areas which work with DMA you can't have it as imprecise.Probably worth me having a look at more of those sources in case there are other nice tidbits to learn from.
Haha. The only thing I can think of is my measurements, as published on AF: https://www.atari-forum.com/viewtopic.p ... 85#p478885 & https://www.atari-forum.com/viewtopic.p ... 89#p478889.Or if you still have some ancient knowledge of other clever things that was done for CT60/PCI/SV that I could benefit from.
TL; DR version is that: always use move16 when copying between TT and VRAM (any combination) and always use move.l when copying to ST RAM.
Good read, funny you had the same idea 12 years earlier.mikro wrote: Thu Oct 08, 2026 12:28 am as published on AF: https://www.atari-forum.com/viewtopic.p ... 85#p478885 & https://www.atari-forum.com/viewtopic.p ... 89#p478889.
agranlund 2026: hmm, wonder if this might work. it does! I am so clever!
mikro 2014: hold my beer...
Atarian Computing
@agranlund Yo! I'm about to update my Raven to the latest release, but I can see you're about to release a new one. Is that imminent, and should I wait, or should I go ahead with the current release?
I’ll package the latest stuff tonight. Better to wait for that as it fixes some stuff I broke in the previous releaseAtarian Computing wrote: Tue Oct 13, 2026 7:02 am @agranlund Yo! I'm about to update my Raven to the latest release, but I can see you're about to release a new one. Is that imminent, and should I wait, or should I go ahead with the current release?
