Odd if desktop doesn't work, but loading a game doesIcky wrote: Tue Nov 27, 2018 7:25 pm I thought that too. Changed res and it still has that purple dark mode.
Video driver thoughts
Re: Video driver thoughts
Does the diagnostic cart have a RGB test ?
Yes there is a colour test. I also reverted to original configuration to compare.
Colour test using Diag cart with Video DAC board in place:
Colour test using Diag cart with original circuit in place:
How odd.. half looks like its not bright enough.. but doesn't explain odd colours getting mixed in...
maybe I have screwed up one of the RGB lines on the chip or something
Also using DiagCart in original mode the background is blue with white text.
Using the Video DAC board the background is black with slightly yellow text.
Original:
Video DAC Board:
Original:
Video DAC Board:
Well here is the diagram..
and the pdf...
https://www.exdwh.com/data/STV8438CV.pdf
There is also the wiring between the schematic and the actual device.. will try and post that shortly to check...
and the pdf...
pinout for the package...
I'll start to take a look. In the mean time here is the boot to desktop using the Video DAC board.exxos wrote: Tue Nov 27, 2018 8:05 pm Well here is the diagram..
and the pdf...
Is there any benefit from me duplicating the results at the mo? Or should I wait on assembling it?
I would build it, see if you have the same issues.. I mean maybe its a bad chipForgottenmyname wrote: Tue Nov 27, 2018 8:16 pm Is there any benefit from me duplicating the results at the mo? Or should I wait on assembling it?
