A new arrival - Amstrad PPC512
Re: A new arrival - Amstrad PPC512
OK, internal wiring is done :)
And it seems to work fine:
But I seem to be having some issues with the intensity bit not working, or being intermittent. So I need to go and check the connection is good.
That looks great Jon.
PhilC wrote: Fri Jul 24, 2026 10:11 am That looks great Jon.
Thanks. :)
Seems the intensity bit was just a bad connection on the RGB2HDMI header, so I've fixed that and it looks like this now:
Whereas before the grey box and text were the same colour. Also, PoP is now behaving differently.
It was flipping between light and dark intensities, but now just works as advertised :)
:dualthumbup:
mrbombermillzy
Post by mrbombermillzy »
Looks splendid Jon.
Make sure you have a go on Prince of Persia before putting it away. :)
mrbombermillzy wrote: Fri Jul 24, 2026 1:56 pm Looks splendid Jon.
I will :)
Even though I'm terrible at it!!!
More proof that the intensity fix is working:
So very pleased with the result :)
Since the display is working great I thought I'd turn my attention to the Picomem since I was using the hard disk and RAM side, but I hadn't tried the sound module.
The Adlib module worked perfectly after downloading sound.com.
I then dragged out an old favourite:
And it just detected a Soundblaster straight away and worked perfectly for sound and music.
It's a great little machine 😁
I can certainly recommend the Picomem that's for sure.
That colour scheme does bring back some memories.
I've got another portable pc on the bench right now, all to be revealed later on.
PhilC wrote: Sun Jul 26, 2026 1:28 pm That colour scheme does bring back some memories.
Cool, screen upgrade perhaps?
rubber_jonnie wrote: Sun Jul 26, 2026 1:39 pm
If and when I get it running,a screen upgrade won't be possible, at least internally anyway.
