Acorn Atom Replica build
Re: Acorn Atom Replica build
And for my next trick: Elite
Though I doubt it very playable with the framerate as is...
And Galaxians:
Which runs at a very nice pace.
Post by HigashiJun »
I'm also wondering why your screen is B&W.
HigashiJun wrote: 01 Apr 2026 11:54 I'm also wondering why your screen is B&W.
It's odd for sure. As I mentioned, the signal at my display is showing as NTSC even on different displays. The crystals are both as specced in the BoM and on the schematic I have.
I'm beginning to wonder if my 6847 is NTSC rather than PAL so I need to check the part number.
I did try an NTSC to PAL converter but it's B&W regardless.
EDIT: It seems the 6847 is NTSC only. So there fore there are additional tricks done to convert the video from NTSC to PAL.
There is apparently a 74LS393 dividing the system clock and generating the extra blank lines to make the frames suitable for 50Hz.
Theres a 74LS74 gating the 6847, a 74LS00/74LS04 combo combining the timing signals and an MC1372 PAL encoder.
I don't remember the MC1372 during the build so I need to go back to the schematic.
rubber_jonnie wrote: 01 Apr 2026 12:00 I did try an NTSC to PAL converter but it's B&W regardless.
Correct me if I'm wrong, but isn't this CRTC programmable, so you can set it to PAL or NTSC ?
rubber_jonnie wrote: 01 Apr 2026 12:00 I'm beginning to wonder if my 6847 is NTSC rather than PAL so I need to check the part number.
(Sorry, quoted the wrong sentence...)
Yay!
That's odd. I did a post and clicked submit but it obviously never appeared.
My Atom would indicate a grey scale NTSC signal via composite video
For colour you need to fit a colour board or build the rgb2hdmi board I've sent you :D
rubber_jonnie wrote: 01 Apr 2026 12:00 EDIT: It seems the 6847 is NTSC only. So there fore there are additional tricks done to convert the video from NTSC to PAL.
Yep. There's a whole section of the Dragon PCB just to try to convert NTSC to PAL (badly)!
I think Acorn decided well to use it as monochrome out as otherwise it'd be all green, like the CoCo/Dragon. Motorola, in their infinite wisdom, never thought that people may want "white" as a colour.
PhilC wrote: 01 Apr 2026 12:21 That's odd. I did a post and clicked submit but it obviously never appeared.
Interesting, I wonder if the green is only from the modulator then? So A bit like the Beeb & Electron that need mods to get colour out of composite. That would make sense.
@HigashiJun From what I can tell there is only one flavour of 6847 and it's NTSC.
rubber_jonnie wrote: 01 Apr 2026 12:25 Interesting, I wonder if the green is only from the modulator then? So A bit like the Beeb & Electron that need mods to get colour out of composite. That would make sense.
Sense has nothing to do with it... The Motorola engineers baked it into the chip design.
Users browsing this forum: ClaudeBot and 23 guests
