Voodoo Rush. I seemed to remember it was crap because it shared RAM bandwidth.Mikerochip wrote: 16 Feb 2026 23:11 There was a Voodoo I with a 2D video card hammered on to the PCB, but, it was still a separate card, really
I have one with a ram problem that was given to me by @mrbombermillzy, so should be able to test once I've fixed it.alexh wrote: 18 Feb 2026 11:55Voodoo Rush. I seemed to remember it was crap because it shared RAM bandwidth.Mikerochip wrote: 16 Feb 2026 23:11 There was a Voodoo I with a 2D video card hammered on to the PCB, but, it was still a separate card, really
luciodra
I found these cards with GL5429 and 512Kb but they have a strange RJ45 (?) connector instead of VGA. Do you know of a cable or adapter that might work ?
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
simon.osborne
Quick search gave me this https://forum.vcfed.org/index.php?threa ... 486.47219/ which linked to a cable guide at https://dougburbidge.com/vgaovercat5.html
This cable appears to be the right kind https://www.ebay.co.uk/itm/266552842152
luciodra
So it's a video card, and that's already great for me.simon.osborne wrote: 20 Feb 2026 01:18 Quick search gave me this https://forum.vcfed.org/index.php?threa ... 486.47219/ which linked to a cable guide at https://dougburbidge.com/vgaovercat5.html
Thank you !
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
Mikerochip
If I had to guess, I'd assume it was to drive some kind of projector/display.
So, for sineage, or whatever.
NEC were all over that market for a long time. They have heaps of displays that can be controlled across serial, too.
agranlund
I wonder if it requires any extra circuitry on the receiving end or if a passive adapter is enough?
GD542X doesn't need more than RAM and bios ROM so I'm wondering mostly because of the more than usual amount of external chips on the card.
One of those are probably the bios rom but the other? That is super interesting and I didn't know VGA over CAT5 was a thing :)
If it was me I'd go in with the expectation that it may not work and that that is a perfectly ok outcome. Or that it requires research, work or modifications to get it working.
Would mainly be concerned if one of those extra ICs converts the VGA signal from the GD5429 somehow and it requires something active on the receiver side. Or if it was just built to output something that wasn't ever meant to go into a PC monitor. PAL/NTSC encoder IC to display on TV or projector taking such signal?
Or.. maybe it just works with an adapter :)
luciodra
We'll know soon. I bought two for 20 Euros and a passive adapter on Amazon. A few days and we will know... :lol:
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
Mikerochip
The longer you look at it....agranlund wrote: 20 Feb 2026 17:42 I wonder if it requires any extra circuitry on the receiving end or if a passive adapter is enough?
Even more interesting, when you do look at it, is why are there a bunch of diodes, those ferrite beads, and then, the big ass voltage regulator?
I'd be throwing a multimeter on that, before I let it near a monitor @luciodra
Take some high res photos, if you can, too!
luciodra
Ok, thank you.Mikerochip wrote: 20 Feb 2026 19:16The longer you look at it....agranlund wrote: 20 Feb 2026 17:42 I wonder if it requires any extra circuitry on the receiving end or if a passive adapter is enough?
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
