luciodra
Post by luciodra »
Atarian Computing wrote: Sun Jan 11, 2026 6:21 am
agranlund wrote: Sat Jan 10, 2026 8:57 pm
Nope, not sure. What card and driver is this?
I guess I had somewhat of the opposite issue with the image looking good (as far as I can tell) on the monitor but very washed out in screenshots taken by the framegrabber, to a degree very similar as you posted.
Randomly changing OBS settings somehow made it look the same as on the monitor but I don't know what setting it was :lol:
Interesting. For me it happened with both the ET4000AX and GD5434. I could've sworn that one time with the Mach64 the colors were spot on.
I decided to check further and found a cheap-ass VGA->HDMI converter, and sure enough, the colours seemed fine, albeit a tiny bit on the bright side. This tells me that the VGA output is fine from the card, and it's just that my monitors are not handling it properly or something.
This particular VGA->HDMI can't handle the BIOS resolutions and has some ghosting, so I might try to find a better one. What are you using and would you recommend it?
The discussion on VGA-HDMI adapters is very interesting. I was convinced that my video card had problems, with artifacts present especially when starting the PC, then I tried another adapter that I had and now everything is perfect. I didn't think it could depend on this.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
Atarian Computing wrote: Sun Jan 11, 2026 6:21 am This particular VGA->HDMI can't handle the BIOS resolutions and has some ghosting, so I might try to find a better one. What are you using and would you recommend it?
Yeah getting a VGA->HDMI adapter that handles all older PC resolutions properly or at all feels like a can of worms.
My best tip would maybe be retro youtubers presenting their capture solutions, and the comment sections of those videos.
My monitor has a VGA input so I'm using that.
It's an older ProArt model and I'd like to say the colours are accurate but it was a long time since it was calibrated and used for photo editing so who knows :lol:
agranlund
Post by agranlund »
I was cleaning up and cable managing my Raven build and ended up starting sketching on this guy:
The 44pin header lines up with the one on the motherboard and the idea is that you connect them with a short cable.
With this, I can easily support decoding additional master+slave pairs which are exposed on the IDE headers.
Screenshot 2026-01-10 at 21.20.32.png (439.52 KiB) Viewed 729 times
Haven't fully made up my mind what else goes onto it yet but most likely at least an RTL8019AS so I can get rid of the ethernet card and come out even on amount of ISA slots used.
Atarian Computing
Post by Atarian Computing »
agranlund wrote: Sun Jan 11, 2026 12:37 pm I was cleaning up and cable managing my Raven build and ended up starting sketching on this guy:
Ooh, nice! If it's not super difficult, this would be perfect for a ROM-port
LarryL
Post by LarryL »
Wow, cool…
Does that mean, more than one (two?) IDE interface, i.e. up to 4 IDE drives?
Atarian Computing
LarryL wrote: Sun Jan 11, 2026 3:45 pm
Wow, cool…
No, if I understood correctly, the gray one plugs to the motherboard giving you two IDE ports on the ISA card, master and slave. Although "additional master+slave pairs" does sound like extra two...
luciodra
Post by luciodra »
:o
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
LarryL wrote: Sun Jan 11, 2026 3:45 pm Wow, cool…
Yep it can easily decode and support multiple ports, and each port can have one master + one slave as usual.
I haven't fully committed to the layout yet but I do know I want a CF socket right on the card itself, so that's a master on one port.
The two headers would mean up to 4 devices on top of that. That's surely overkill and I've been thinking perhaps reduce it to one.
But then I keep reminding myself that master/slave could be a bit of a lottery even back in the days on PC and it was a thing to avoid hooking stuff up as slave unless as a last resort.
I don't remember it being as bad as this article though :)
https://www.os2museum.com/wp/the-dual-drive-ide-hell/
I'm sure it got a lot better over time. Today I assume the situation is worse again with all the cheap no-brand stuff.
LarryL
Post by LarryL »
agranlund wrote: Sun Jan 11, 2026 7:19 pm
Excellent idea - the more, the better :mrgreen:
And I think having at least one standard 40p port makes things easier for e.g. CD/DVD drives
Atarian Computing
agranlund wrote: Sun Jan 11, 2026 7:19 pm Yep it can easily decode and support multiple ports, and each port can have one master + one slave as usual.
Oh wow. So, somehow, you would use the OG IDE to generate two Master/Slave pairs? Or is it a passthrough for the built-in, and you're creating a new master/slave from the ISA? But either way, that's really cool. Having multiple drives is almost essential. I'm in the boat where I regret my partitioning choices and would like to redo that. I'd need an extra drive or two to do that without hassle.
