Falcon + CUBASE AUDIO + SCSI - Experiences?
Re: Falcon + CUBASE AUDIO + SCSI - Experiences?
Does anyone in the UK have a Falcon test hardness for DSP testing myself badwolf could borrow for a bit ?
exxos wrote: 25 Sep 2025 14:26 a Falcon test harness for DSP testing
Is that CB102844?
Make your own for £2?
https://www.atari-forum.com/viewtopic.p ... 40#p466564
mikro
Post by mikro »
whomper wrote: 24 Sep 2025 15:46Without DFB1X everything passes, with it I get these messages on a few runs.
I may be wrong but if the diag cart doesn't use handshaked i/o with the DSP, a 50 MHz 030 can shake its tests quite a lot.
Unless @Badwolf had this test running during his DFB1 development, of course.
alexh wrote: 25 Sep 2025 15:30
Is that CB102844?
@whomper would be better to answer..
I assumed it would need the full test harness as well, but no idea..
mikro wrote: 25 Sep 2025 15:42
OPTION jumper would help as it limits the CPU to 16MHz...
exxos wrote: 25 Sep 2025 15:48
mikro wrote: 25 Sep 2025 15:42 I may be wrong but if the diag cart doesn't use handshaked i/o with the DSP, a 50 MHz 030 can shake its tests quite a lot.
No, I didn't test it but I did see similar failures at OPTION1 speeds. Assumed entirely because test harness missing, but now I'm not so sure and will probably look into this further after CL4.
exxos wrote: 25 Sep 2025 15:43
alexh wrote: 25 Sep 2025 15:30 Make your own for £2?
The DSP bit looks like it just needs the plug wiring. I don't know how easy it is to lay hands on that sort of plug, but if push comes to shove I may try to make one with 3d printing and some solid core wire.
whomper
Post by whomper »
This is what I have. Seems like a DIY plug based on previously linked wiring guide. Not sure why bother with hot glue.... Its not like there's deep IP there
Whomper
Homepage
Electronic Lab
16 Bit: Falcon (DFB1X/14MB/4+8 GB), 1040STFM, Soundpool SPDIF/FA8, Cubase Audio, Cubase 3
8 Bit: 1200XL, 800XL, 2 x 1050, 1025, Fujinet Pro, 2 x 1010, CX-85, Touch Tablet
Looks like china still sell them..
Meanwhile in the uk... I'm tempted to go for this if it's the right connector...
https://www.ebay.co.uk/itm/396918510518 ... R4CziqawZg
Edit:
Found a bit cheaper seller and bought one. Hopefully it will fit. :)
mikro
Post by mikro »
whomper wrote: 18 Sep 2025 18:54I can send you my audio tracks so that you can replay it exactly. the bluescsi used an interesting images concept where you create 1GB images and then bluescsi reports it as separate drives to HDDriver.
Can you publish the song somewhere so we can try it on more setups?
Also, how Cubase enforces this SCSI requirement? You really can't just open a song from an IDE disk? (sorry, a total Cubase newbie here)
Btw thanks to this investigation I have just found out that SCSI on my CT2 Falcon is totally broken. Cool.
exxos wrote: 25 Sep 2025 20:38 Meanwhile in the uk... I'm tempted to go for this if it's the right connector...
Oh yeah. That looks the stuff.
Where's the cheaper one?
EDIT: this one? https://ebay.us/m/fMaskn
Users browsing this forum: ClaudeBot, Google [Bot] and 34 guests
