Hello
I have a issue with psu DVE DSP-508A. I cant find right resistors described as R5 and R6.
Part list is incomplete.R5 50??? R6 1/4watt? On board was 2watts 3.3kohm.
I removed old ones (looks burnt) one is 47kohm next 330ohm (on ohmmeter)
At this moment im totally confused. Please advise.
PSU repair issue DVE DSP-508A for Atari STFM
Best regards
Wes_T
/ ZX 81 16kB / ZX Spectrum 16kB / ZX Spectrum 48kB / Atari 800XL / Atari 65XE / Atari 520 STFM / Commodore VIC20 / Commodore C16 / Commodore C64 / Amiga 1200 /
Wes_T
- frank.lukas
Re: PSU repair issue DVE DSP-508A for Atari STFM
Both measured values are correct and also match with the color code. The list/BOM is incorrect I think ...
Do you really have to replace the two resistors?
Thank You
Not yet i will order them soon. I just need to be sure.
So that should be 2watts, 47kohm and 330ohm.
Best regards
Wes_T
Wes_T
- frank.lukas
There are R4 and R20 ...!
Ok. R4 on manual is described as 3300ohm
This one i measured one is 333ohm, coulor code looks like 330ohm (photo)
R20 47kOhm, ok
On photo you can see how this is described on the board.
Board is rev.0
Probably i have different material specification. But is described as for DSP-508A
R20 47kOhm, ok
Board is rev.0
Best regards
Wes_T
Wes_T
