PiRTOII and ColecoVision Megacart builds
Re: PiRTOII and ColecoVision Megacart builds
:dualthumbup:
Just arrived:
:girldance:
Post by HigashiJun »
Yay !
:cheer:
More yay 😁
Should be able to get them started today, probably even finished.
Need to go find some ROM files 😁
There are not so much components to solder, so you should be good today.
HigashiJun wrote: Thu Oct 31, 2024 12:37 pm There are not so much components to solder, so you should be good today.
I think so :)
The only issue I have is that there is a diode on both boards that protects the console if the 5v is left connected to the Pi, but I can't find what diode to use. I suspect a 1n4148 would do the job but I like to be sure.
EDIT - Found the diode, it is a 1n4148 :)
And built:
Also now programmed so I just need to find some ROMs and we're off to the races.
The blue PCB is also for Coleco, but I'm going to do that later.
Coleco cart tests great :)
Need to do the same for the Intellivision and then start adding more carts :)
:dualthumbup:
I knew that TMS VDP blue and white display would appear at some point.
stephen_usher wrote: Thu Oct 31, 2024 3:41 pm :dualthumbup:
For sure!
