BOOKMARK THIS PAGE !
Testing the blitter
PaulJ
Re: Testing the blitter
Post by PaulJ »
Should un solder sj1 & 2 right?
PaulJ wrote: 22 Oct 2018 15:34 Should un solder sj1 & 2 right?
Yes.
:bravo: we have Blitter on the STF now :) great work exxos
PaulJ
Post by PaulJ »
exxos wrote: 22 Oct 2018 15:32
PaulJ wrote: 22 Oct 2018 15:28 I've been homing out lines other than address and data... all look good so far. What was the issue you had? Something I need to change?
I un-soldered the wrong jumpers :)
Working also!!
So no problems with the blitter then it seems :thumbup:
PaulJ
Post by PaulJ »
exxos wrote: 22 Oct 2018 18:05 So no problems with the blitter then it seems :thumbup:
Nothing other than supidity on my part which luckily was able to overcome! :mrgreen: :mrgreen: :mrgreen: :mrgreen:
PaulJ wrote: 22 Oct 2018 18:33
You two are giving me Blitter envy :mrgreen:
Users browsing this forum: CCBot and 1 guest
