Amiga 2000 stopped working... (FIXED)
Re: Amiga 2000 stopped working...
My hunch is that the system is halting as soon as the ROM code tries to do any I/O.
Given that the first thing that DiagROM tries to do is write to the serial port but the Kickstart ROM probably does a memory test first would be why one runs for longer before stopping.
BennehBoy
So that circles back to a bus error then? And maybe those LS245s?
- Admin sponsor
But since he's measured ROM /OE and it never goes low it's not. It's not even enabling the ROM to execute codestephen_usher wrote: 14 Jun 2024 16:49 My hunch is that the system is halting as soon as the ROM code tries to do any I/O.
Kepler
This is interesting...if I remove U300 and measure the voltage at pin 2, it reads 0.45v at start up. If I insert U300, it measures 5v at start up...
Actually, now that I have seen and read the previous posts, this is correct behavior.
BennehBoy
You said you tried all the custom IC's in another board... what about the CPU? EDIT, although it wouldn't explain OE on the ROM...
Kepler
I wish I had missed that and it was the cause of this grief...but it was the first IC I replaced. 😭
- Admin sponsor
Is there any way you can capture /AS low and ROMOE at gary at the same time on your scope? trigger on the falling edge of /AS once .. if you could hold the machine in reset with the power on beforehand that would be even better.Kepler wrote: 14 Jun 2024 18:07 I wish I had missed that and it was the cause of this grief...but it was the first IC I replaced. 😭
Kepler
Capturing both would require two leads presumably?
How do I hold the machine in reset with the power on?
- Admin sponsor
Short the reset line to ground until you are ready or if you have a helping hand hold CTRL-AMIGA-AMIGA , set the scope to trigger then let go.Kepler wrote: 15 Jun 2024 03:24 Capturing both would require two leads presumably?
@terriblefire given that the OP is reporting different symptoms depending upon which ROM is installed, do you think it may be a good idea to perform this test without either ROM installed, just in case the fault is being compounded by the ROM chip(s)?
