... it wasn't until after I proudly had soldered my contraption to the board that I noticed that the DIL14 socket I thought I had used was still lying on the desk ...
Troed - progress
troed
Re: Troed - progress
I have those moments.troed wrote: 09 Oct 2018 21:20 ... it wasn't until after I proudly had soldered my contraption to the board that I noticed that the DIL14 socket I thought I had used was still lying on the desk ...
troed
In transit:
32.08 crystal
Video unf*ck board
Missing from the parts kit:
72LS02 - and it seems I don't have one in all of my 74xx collection. Will order.
- edit #2: Ah! Actually I have a bunch of 74ALS02. So unless it needs to be "slow" that should work ;)
Everything else I need to boot up populated now. What might be different from others is that I will use IMP DMA and Shifter.
edit: Ah, no, still need to steal an MFP crystal from one of my (all working) machines.
32.08 crystal
Video unf*ck board
I had no issues with the IMP shifter and DMA, so you should be ok (famous last words)
troed
Were you using a complete IMP kit? My GLUE and MMU are RicohForgottenmyname wrote: 10 Oct 2018 20:26 I had no issues with the IMP shifter and DMA, so you should be ok (famous last words)
No just the shifter and dma. Emails now back in my Mega but still using the IMP shifter
troed
First boot: Stable white 60Hz screen. Usually an indication TOS isn't executing or being held in RESET.
Not sure when I'll have time to debug, but, I do know I haven't soldered a reset switch to the board, thinking that it was only needed if I want to ... reset. Am I not thinking that through?
Reset switch shorts out a capacitor which then re-charges to trigger a reset.. so it shouldn't matter if there isn't a reset switch... you may need to up the value of a cap to 47uF (from 10uf) as I think icky had reset issues.
Not me :) Think it was Forgottenmynameexxos wrote: 13 Oct 2018 10:47 Reset switch shorts out a capacitor which then re-charges to trigger a reset.. so it shouldn't matter if there isn't a reset switch... you may need to up the value of a cap to 47uF (from 10uf) as I think icky had reset issues.
Good progress though troed.
yeah it was me, still messing around with that but just takes 1 reset and off it goes for now.
Users browsing this forum: Baidu [Spider], ClaudeBot and 2 guests
