exxos's linux mint install blog
Re: exxos's linux mint install blog
I asked the AI how to do the command in startup but it didn't work :(
One post said I need to enable systemd. Seems that's done in the grub boot menu. Did that. Still didn't work.
sudo systemctl status rc-local
● rc-local.service - /etc/rc.local Compatibility
     Loaded: loaded (/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: enabled)
    Drop-In: /usr/lib/systemd/system/rc-local.service.d
             └─debian.conf
     Active: failed (Result: exit-code) since Tue 2024-04-16 14:05:18 BST; 4min 51s ago
       Docs: man:systemd-rc-local-generator(8)
        CPU: 1ms
Apr 16 14:05:18 chris systemd[1]: Starting /etc/rc.local Compatibility...
Apr 16 14:05:18 chris rc.local[2136]: Can't open display
Apr 16 14:05:18 chris systemd[1]: rc-local.service: Control process exited, code=exited, status=1/FAILURE
Apr 16 14:05:18 chris systemd[1]: rc-local.service: Failed with result 'exit-code'.
Apr 16 14:05:18 chris systemd[1]: Failed to start /etc/rc.local Compatibility.
So no idea whats going on. I'm not going down the rabbit hole again just to autoload screen brightness. This should have been a standard option and simple to do since day 1 IMHO :roll:
Oh you're using Plasma desktop environment? I think those options are only available on the default MX desktop (XFCE)
Perhaps you need to do something like this for Plasma, ie; add a widget:
https://github.com/davidhi7/ddcci-plasmoid
But I'm not an expert on Plasma at all, never used it personally.
If you ever have issues on one desktop environment, you can install another. Might be worth using the standard XFCE desktop with MX Linux since that's their main base, ie; 90% of users will default to that, and as such it will get more feedback and features are worked on there first.
I just read back in my old comments of this thread... I must be a fortune teller
There is also this:
https://store.kde.org/p/1325685/
0
The Plasma 5 applet Display Brightness Control solved this issue for me.
I installed it with this command:
plasmapkg2 -u risu.brightness.bar.v1.1.plasmoid
I can now change the display brightness from a KDE Plasma applet in the task bar.
Steve wrote: Tue Apr 16, 2024 2:32 pm I just read back in my old comments of this thread... I must be a fortune teller
I can't remember why I went for plasma, probably seemed easier and the best choice for me at the time. But if they are not developing it much.. it was kinda pointless choosing it then. I've had the same with desktop themes, I won't touch those as it WILL break the whole OS.
I tried the git you posted.. in the end..
$ ddcutil detect
Open failed for /dev/usb/hiddev0: errno=EACCES(13): Permission denied
No displays found
This is why I just give up with software. After screwing with windows for 30 years getting stuff to work right, moving to Linux is like going a huge 30 year step backwards. I wasted enough years of my life the first time around. Plus I can't spent much time on the PC anymore due to my RSI. So rather than trying to reinstall the desktop, which will no doubt break everything I've setup already, I will just have to live with the annoyances I guess.
