I agree. Have you checked for a clock signal on the CPU at all? a diagnostic cart won't mean a thing if the CPU has no clock signal.
Check the basics first.
@stephen_usher and @rubber_jonnie, thanks. Yes, I had checked the clock signal to the CPU and it seems to be correct for boot (~8MHz).rubber_jonnie wrote: 13 Nov 2023 15:59I agree. Have you checked for a clock signal on the CPU at all? a diagnostic cart won't mean a thing if the CPU has no clock signal.
Thanks. That seems reasonable. It seems to be detecting the proper frequencies, so I think it's OK.Steve wrote: 13 Nov 2023 19:36 @hunsra your monitor will tell you if it's not syncing, there's no point in guessing.
Thanks. I will do that and also review the rest of the mandatory fixes topic.exxos wrote: 18 Nov 2023 16:28 Change the caps in the reset circuit or add larger ones. It's a known issue in the mandatory fixes section.
Check 0.5A fuse.hunsra wrote: 18 Nov 2023 16:26...Also, the cartridge port doesn't seem to work. It boots to the desktop whether the diagnostic cartridge is inserted or not...
Indeed. I was beginning to think it was a lost cause.
