Building a DIY large bed 3D printer
Re: Building a DIY large bed 3D printer
Aluminium light weight CNC kit arrived yesterday for the Giant Panda printer. I have considered an Ali kit before but they have all been th e past exact copies of the printed parts making them heavy. This kit has had the parts redesigned for Ali / CNC and are lighter and on par with the printed components. I may have to rename the printer to the Giant Red Panda as the accent colours for the Ali kit are only available in red. Will see once it's been rebuilt.
zfrenchy
Post by zfrenchy »
Icky wrote: Tue Oct 01, 2019 11:14 am Have settled on the name Giant Panda for this beast. The custom aluminium print bed (550mm x 350mm x 8mm) was delivered last week. It has been milled to provide the four mounting points on each long side. As you can see with the ST case bottom for size, it fits nicely and the heater bed is next to stick to the bottom of the plate.
Any luck you can give tell me where you got this custom bed ?
zfrenchy
Post by zfrenchy »
Icky wrote: Fri Dec 13, 2019 9:30 am Finally received the PEI sheet for the print bed. Hoping to do a test print this weekend of an ST Case backplane to see how the printer copes with a large length print.
... Same as the bed, what is the source for the custom PEI surface ?
mrbombermillzy
Post by mrbombermillzy »
Icky wrote: Sat Mar 11, 2023 12:18 pm I may have to rename the printer to the Giant Red Panda as the accent colours for the Ali kit are only available in red.
Perhaps some time in the sun could possibly turn the colour of the parts to a vague shade of pink? ;)
zfrenchy wrote: Wed Jul 19, 2023 2:32 am Any luck you can give tell me where you got this custom bed ?
Sure, these folk https://clever3d.de can make an aluminium bed to any size and specification.
zfrenchy wrote: Wed Jul 19, 2023 2:36 am ... Same as the bed, what is the source for the custom PEI surface ?
Yep, these folk can do surfaces to order ENERGTIC 3D Store
https://a.aliexpress.com/_EvNKEix
Lastly these folk can provide a heat pad to size specification too Shop3478063 Store
https://a.aliexpress.com/_ExSkyb5
zfrenchy
Post by zfrenchy »
Thank you for your kindness
Open heart surgery on the Giant Panda yesterday. I think I may have to change its name as the accent colours change from white to red. Giant Red Panda may be. It's going to take a while to finish this upgrade project.
mrbombermillzy wrote: Wed Jul 19, 2023 8:02 am
Pink, @exxos would like that :)
Icky wrote: Mon Nov 13, 2023 8:52 am Open heart surgery on the Giant Panda yesterday. I think I may have to change its name as the accent colours change from white to red. Giant Red Panda may be. It's going to take a while to finish this upgrade project.
A little disappointing to see that neither of your beverage conveyances are Phoenix mugs.
rubber_jonnie wrote: Mon Nov 13, 2023 10:36 am A little disappointing to see that neither of your beverage conveyances are Phoenix mugs.
They are in the dish washer. Although this was a coffee and tea based beverage project.
