Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
That doesn't seem to happen. All that happens when I press reset is it seems to screw up the com port and I have to unplug the usb and restart the program. If I press esc I get the HDC prompt . So it's not like comms isn't working.
dad664npc
Post by dad664npc »
okay so if you see the prompt type status
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
PiStorm JIT dev - https://github.com/gotaproblem/pistorm-atari-jit
dad664npc wrote: Mon Jun 19, 2023 9:43 am okay so if you see the prompt type status
So the one in my test board is
BBaN RPP HDC
ATARI ACSI HDC Emulator
Build date May 18 2023  12:56:45
Release 1.01
Steve Bradford aka cryptodad
CONTROLLER ID: 0
sd0: unmounted - command packets 0
sd1: unmounted - command packets 0
We have been running for 0 days 00:00:16
CPU clock is running at 150 MHz
SPI clock is running at 4294 MHz
So need to download all the files you sent and see which one that version is then.
Found that version and flashed in one of the new boards. Now it boots right up with HD11, though the write problems are still there :(
When trying to delete files from C: it does this..
CMD_READ        tgt=0 lun=0 (0x08:00:a5:28:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:38:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:48:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:58:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:68:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:78:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:88:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:98:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a4:48:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a5:a8:08:00) (00)
TEST_UNIT_READY tgt=0 lun=0 (0x00:00:00:00:00:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:a6:98:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ab:68:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ab:b8:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ac:28:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ac:38:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ac:68:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:ac:98:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:9b:a8:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:8a:88:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:01:88:08:00) (00)
CMD_READ        tgt=0 lun=0 (0x08:00:00:b8:08:00) (00)
Then just pops up the usual error box on the desktop.
exxos wrote: Mon Jun 19, 2023 11:00 am When trying to delete files from C: it does this..
Just out of interest (there are no CMD_WRITEs there), if you hit ESC to refresh the window, or reset the machine at this point, do you see a CMD_WRITE log message appear before the next command that works?
I've a theory something hangs before or during the write starts up on my one which stops the log flushing for whatever reason.
Badwolf wrote: Mon Jun 19, 2023 1:31 pm Just out of interest (there are no CMD_WRITEs there), if you hit ESC to refresh the window, or reset the machine at this point, do you see a CMD_WRITE log message appear before the next command that works?
Not sure, it's "off my desk" now as the DFB1's have arrived. So I can't do any testing currently now.
But indeed I never saw any writes in the log during all the "hangs".
DaveC
Post by DaveC »
Well the new firmware seems to work fine here with my STe, so that's me happy!
chronicthehedgehog
Post by chronicthehedgehog »
DaveC wrote: Mon Jun 19, 2023 4:04 pm Well the new firmware seems to work fine here with my STe, so that's me happy!
Me too. I've been doing quite a bit of experimenting with partitioning and installing the likes of Neodesk etc and it feels really solid.
dad664npc
Post by dad664npc »
The debug prints are handled by CPU0 - occasionally a print will be missed because CPU0 loop is checking to see if a key has been pressed and if micro-sd cards have been inserted/removed
Just to confirm, I've quickly got my STFM mobo up and running and the open-source branch from Jan '21 with my minor mods for my board design faux pas does indeed work. Including write. I've not tried the latest commercial firmware yet, but I suspect that will if this does.
Ruddy 'bad' STE DMA strikes again! :)
Post by JezC »
@exxos Any idea if/when you might have more of these available in your store?
