RAM Upgrade for a 520ST
Colleton
Post by Colleton »
I have a nice 520ST with TOS 1.04 that I'd like to upgrade the memory on.
I plan on using the Exxos ST/F/M / MEGA ST-RAM 4MB UPGRADE [0035] upgrade, but am lost as to which of the 3 cables I should get.
I'm attaching a pic of my motherboard so that layout can be seen. Any advice would be appreciated. Thanks!
Re: RAM Upgrade for a 520ST
Locate the MMU, which as I recall is the furthest left PLCC socket on your mainboard, and measure the distance to the Shifter which is in the tin can on the right hand side, then use that measurement to judge the cable size you need, without the cable being under tension when installed.
As it happens, I will probably be upgrading mine later today.
I have a 30cm cable as it was originally intended for one of my Megas, which I got fixed, so I can confirm if it's longer than you need.
I'd suspect as @exxos says, 20cm is going to be enough.
Just opened mine up, 20 cm it is.
This is it fitted to mine with a 30cm cable, once again confirming the 20cm option.
I did remember the MMU position incorrectly though, it's the chip here you can see the MMU adaptor on top of (Unsurprisingly!), the other, towards the left, being the GLUE.
Colleton
Post by Colleton »
Awesome, great info. Thanks everyone!
Colleton wrote: 03 May 2020 13:26 Awesome, great info. Thanks everyone!
No problem and good luck.
Colleton
Post by Colleton »
Received the 4MB MMU ram upgrade this weekend, and got it installed in my 520ST this afternoon. Everything went very smoothly, no problems at all.
Also installed a blitter in my STFM. It was a busy day today.
Colleton wrote: 18 May 2020 04:33 Received the 4MB MMU ram upgrade this weekend, and got it installed in my 520ST this afternoon. Everything went very smoothly, no problems at all.
Good job sir, it's a very nice upgrade.
Return to “RAM UPGRADES”
Users browsing this forum: ClaudeBot and 209 guests
