Could you take two photos for me please:coonsgm wrote: Mon Nov 09, 2026 1:41 pm All three TT Ram tests freeze.
The desktop is clearly accelerated with the rapid animations suggesting that TOS on RAM is working
I will continue to see if I can have find any hardware issues (bad soldering by myself).
Thank you again for all the help!
1. The memory test screen when the machine boots, so I can see exactly what it shows for ST RAM and whether anything at all appears for TT RAM.
2. The TTCHECK screen once it has frozen. Even if it looks like nothing happened, I need to see whether the title line and the _ramtop / _ramvalid / phystop line appear, and the last line it printed before it stopped.
You should see this on boot up (do not press any keys as it would skip the tests)
Obviously TTram is working as the ROM CRC copy passes.. But at this point, if you dont see the TTram check bar, then TOS has marked the RAM as bad for some reason and does not run the checks.. Which is of course a bit contradictory if ROm to TTram passes and works fine.. unless the bottom end of SDRAM is faulty for some reason.
