- arkadiusz.makarenko
- Moderator Team
Re: REV 3 - The beginning
Woof!exxos wrote: Sun Apr 11, 2021 11:27 pm Holy heck.. EMUTOS is fast on a 030! I swear the floppy is going faster as well...
I have been playing around with MAPROM this morning trying to get the " copy low RAM variables to fast ram" working,but basically no luck.
Just for comparison, this screenshot is from before of TOS206 running in fast ram only..
Then running MAPROM which is actually running slower for some bizarre reason... I can only assume it is something to do with the MMU look-up tables which is causing this slowdown.
Your sacrifice is not in vain..
Let's see if the printer behaves today for once..
Each having trouble with the nozzles
all the ones I have are blocked up and they are currently in your ultrasonic cleaner
But I have got these new red nozzles.. Problem is these ones are too big for the pads which I am trying to print.. So been fiddling for the past couple of hours to get the pressure just enough to get the paste flowing, and fast enough to get a thin spread of paste on the pad.
The slightly larger pads I am drawing a circle basically on them to get more paste down.
- BlankVector
For completeness, EmuTOS 1.0 has nicer icons. And it has been possible to change them with an RSC file for a long time.terriblefire wrote: Mon Apr 12, 2021 9:22 amI keep telling people to use EmuTOS but they want the nicer icons of 2.06.Which i asked you to put in EmuTOS like back in 2012
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a color pixel in assembly language on Atari ST.
- Admin sponsor
That requires the ability to use these tools ... i did give it a go but got very lost.BlankVector wrote: Tue Apr 13, 2021 2:12 pm For completeness, EmuTOS 1.0 has nicer icons. And it has been possible to change them with an RSC file for a long time.
The project got stalled again
the 144xl chips i have are the 80io version
I've done an order to mouser but no idea when the stuff will turn up.
Doh!exxos wrote: Wed Apr 14, 2021 9:11 am The project got stalled againthe 144xl chips i have are the 80io version
I'm taking an enforced break from mine waiting for some CPLDs too. Doing some 68k in the mean time.
I'm too cool to simply order the wrong ones, though. I mysteriously blow mine up just as they start working!
Welcome to Atari!Badwolf wrote: Thu Apr 15, 2021 10:04 am I'm too cool to simply order the wrong ones, though. I mysteriously blow mine up just as they start working!
