As discussed on various other topics spread across the whole of the known universe (well, OK, this forum then...but that sounds soooo boring in comparison
), below are some zips of files kindly supplied by
@agranlund that allow people with only the standard 192k ROM decode to boot up with a TF536 & load EmuTOS into RAM!
Original files which I used to boot EmuTOS v0.91 from Floppy (Gotek) with a TF536 fitted into an H4.
- tf534_emutos.zip
- EmuTOS v0.91 + 192k Boot ROM image
- (357.19 KiB) Downloaded 268 times
Updated version for EmuTOS v1.0 (note that I have kept using the boot ROM image in the above zip file because I'm lazy!) - I think this is the version I'm still using
A later version was submitted which booted up OK (from Floppy/Gotek)...but for me it stopped the Floppy/Gotek drive from working once it was running from RAM...which didn't help as that is the only file system available to me on my H4 + TF536 system at the moment
So, I've not included that version in
this post but will add another post containing that version for other users with a working IDE configuration.
