Some time ago when searching to see if any company was building new 68020/30/40/60 processors, I found that Rochester Electronics was still making the 68020 and 68040. While the Atari market is well-served with accelerator boards and, more importantly the existing pool of electronic engineers already overcommitted with existing work, meaning that given the small size of the market there is no practical need for yet another Atari clone, would there be any point in designing:
* A 68020 board with 68881/2 socket, full 32 bit bus design for the single-tasking GEM software base. [Possibly socketed for the unobtainium 68851 though I appreciate a FPGA version of that MMU to plug in would take considerable time to make.]
* A 68040 board, again with full 32 bit bus design aimed at the FreeMiNT base
partcularly given that demos and games quite likely would not run on them? I must admit that the 68020 board intrigues me as a proof of concept of what the Mega ST could have been; a fully-32 bit single-tasking TOS computer with the capacity for greater than 4MB memory.
Is there any point in new 68020 and 68040 boards?
Atari Mega ST4, Atari Falcon030 14MB.
Re: Is there any point in new 68020 and 68040 boards?
For me a New Atari ST turbo card would have to have 7MHz 68000 fallback (e.g. plug the original chip into the board for fallback) there is just too much stuff on the Atari that requires exact CPU timing. Most accelerators do not have this option and taking out the accelerator and plopping back the old CPU is a PITA.
If it also supported "ALT RAM" (is that the right term?) and mass storage in 7MHz 000 mode (e.g. 10-14MB extra 16-bit RAM in 24-bit address space and IDE) that would be adventurous.
Jumperless design (some sort of switching by using the state of the keyboard/mouse during reset would be good)
There is a 3.3v 68040 so in theory you could make a Turbo card just for the remake Atari ST motherboards (e.g. H5) I don't remember if they have an FPU/MMU or not
I interpreted him as to be talking about an entire machine, not just an accelerator. Basically with high-level compatibility, for clean GEM apps, but without any low-level compatibility ie; no demos etc.
I really liked the shows I've been to where people brought their Raven's (actively developed Atari 68060 clone) but I found it hard find enough interest to want to make one. The price of the 060 parts were not even a factor.
There was a bit of development done on MiSTer (the FPGA platform) for Atari clones. The Atari Falcon030 core and ST cores using hybrid 680x0 that ran on the ARM chip which was interesting.
From my point of view, yes, if it brings you joy.
In the end all of this is rather 'pointless' but hobbies don't need to make sense
I can only speak for myself of course but the point of Raven is and was purely that -- a supply of fun for myself.
Part of the joy was the board itself, and a much bigger part the software puzzles to solve around something like that, as well as getting an almost 'infinite' supply of low level driver type code one can pick and choose to work on thanks to the ISA bus.
Practically and from a users perspective, a Falcon+CT60 probably makes more sense. Or a Vampire V4SA if you don't have a preference about FPGA vs old chips.
Personally I wouldn't have been able to approach it from the point of view of making something that pleases everyone, I think that would quickly have started becoming a job or died the feature-creep death before any board was made
Interesting topic.
I have a Pak 68/3 accelerator board in my STacy. 68030 and 68882
running at 40mhz and TOS v3.06 (modified).
It's surprising just how much software *does* run cleanly on it.
Especially lately, where coders seem to be taking multiple
scenario's for their software into account. Of course, AI has
to be mentioned here.
The hard drive adapted games from Klaz, Dbug and P.Pera
mostly work on my setup, with the odd exception or some
minor glitch (some major).
For what doesn't work, the Pak 68/3 board has a fall back/
compatibility mode using an actual 68000 chip on it, plus
the STacy's original TOS v1.04 to take care of anything that
doesn't work in accelerated mode.
So I'm not sure I gleaned an actual answer from earlier in
the thread - was this about an add-on board for current
ST models or an entirely new ST system?
Thanks.
Thanks.
As said before: If you enjoy the process why not. I personally find projects like the base64 quite interesting. But since I "only" own a Mega STE the bar is quite high.
That’s right. Behind it is the desire to construct an alternative-universe Mega ST that was a fully-32 bit computer aimed primarily as a faster ST but socketed for 68851 and 68881 so it could be used to run Unix, competing with Apple’s A/UX.Steve wrote: Mon Nov 16, 2026 12:18 pm I interpreted him as to be talking about an entire machine, not just an accelerator. Basically with high-level compatibility, for clean GEM apps, but without any low-level compatibility ie; no demos etc.
Prices are not competitive. Those chips are only there to keep some industrial/military devices operating.
Or use a 68030 core : https://github.com/apolkosnik/AP68030kgilmore wrote: Mon Nov 16, 2026 11:25 am * A 68020 board with 68881/2 socket, full 32 bit bus design for the single-tasking GEM software base. [Possibly socketed for the unobtainium 68851 though I appreciate a FPGA version of that MMU to plug in would take considerable time to make.]
