Flashing new CT60 103e ?
kohli79
Re: Flashing new CT60 103e ?
Post by kohli79 »
mikro wrote: Sat Aug 22, 2026 5:28 am
kohli79 wrote: Sat Aug 22, 2026 12:31 am Thanks, yes, I do have access to AF.
As everything’s working fine so far, the flashing isn’t really a problem for the time being. ;)
I wanted to add support for the other flash type but I lack hardware to test it. If you want to be my tester, drop me a message and I can look into it.
Hi Mikro, thanks for the offer. I’d love to help. :dualthumbup:
However, I’ve actually managed to sort it out somehow. No idea why it suddenly started working. In my Micron folder, where the special CPX for the CT63 with Micron memory is located, there’s also this flash programme. I only discovered it by chance – or rather, I’d simply forgotten about it. It’s the same size as the one in the current ZIP file for the new version. I just added this RSC file and suddenly the flashing process started without any problems. :o
I was very surprised... :D
I now have the new version 1.05 installed on my CT63 and it’s been running without any problems so far. Gembench is even showing higher scores in some cases than before. What is striking, however, is that during the DML FPU Test V1.51, errors are now occurring at certain points that weren’t there before. Always at the same point. The rest runs without errors.
Micron 22.08.2026 14_15_56.png (7.46 KiB) Viewed 91 times
micron_M29F800FT 22.08.2026 14_16_08.png (8.77 KiB) Viewed 91 times
Life is too short not to have an Amiga/Atari. 8-)
mikro
Post by mikro »
You should have read release notes more carefully. ;-)
kohli79
Post by kohli79 »
mikro wrote: Sun Aug 23, 2026 10:27 am You should have read release notes more carefully. ;-)
Can you help me out here!? :?
kohli79 wrote: Sun Aug 23, 2026 3:34 pm
https://github.com/mikrosk/ct60tos/releases
dml's FPUTest 1.51 has pre-recorded its results with the bug present, use a corrected results file: https://atari-forum.com/viewtopic.php?p=497092#p497092 until a new version is available
kohli79
Post by kohli79 »
Thank you very much. :dualthumbup:
kohli79
Post by kohli79 »
There are two new versions. I was able to flash V1.03f without any problems. With the previous version, the OSSC would sometimes have problems synchronising after a reset or after starting up the Falcon. You wouldn’t see the start-up screen at all, and the image only appeared once the desktop had finished loading. However, this was relatively rare.
This problem has now completely disappeared! Thank you. :dualthumbup:
https://atariscne.org/news/
https://github.com/mikrosk/ct60tos/releases/tag/1.03f
https://github.com/mikrosk/ct60tos/releases/tag/3.00
