STFM Booster 2.3 + Dual TOS Kit, TOS 2.06 Issue
Re: STFM Booster 2.3 + Dual TOS Kit, TOS 2.06 Issue
Thanks.. It looks like the yellow line is the booster pin 1 ?
The signal doesn't look as good as it should be. I suggest you put a 68R in series with the wire going to pin 39 of the shifter... try again... if still problems, add another 68 and try again...
Also have you tried a different floppy drive ?
What happens if you press RESET button after it bombs, does it still bomb exactly the same ?
Can you also post close up shot of the ROM board also...
leon22
Post by leon22 »
exxos wrote: Mon Jan 21, 2019 2:15 pm Thanks.. It looks like the yellow line is the booster pin 1 ?
No, its Pin 39!
exxos wrote: Mon Jan 21, 2019 2:15 pm The signal doesn't look as good as it should be. I suggest you put a 68R in series with the wire going to pin 39 of the shifter... try again... if still problems, add another 68 and try again...
Tried it with same result: (I used 2x27R + 2x40R)
exxos wrote: Mon Jan 21, 2019 2:15 pm Also have you tried a different floppy drive ?
Not yet, because I only have another floppy drive from an Amiga 1200 around! I'm not sure if they are compatible?!
exxos wrote: Mon Jan 21, 2019 2:15 pm What happens if you press RESET button after it bombs, does it still bomb exactly the same ?
The same -> 4 bombs (but without memory test)
exxos wrote: Mon Jan 21, 2019 2:43 pm Can you also post close up shot of the ROM board also...
Voila:
Very strange...
I don't see how TOS104 works at 16MHz but not TOS206. Its like TOS206 ROM is corrupted, but you said it works at 8MHz ?
Can you boot TOS104 and run GB6 for a couple hours and see if TOS104 is stable at 16MHz..
http://www.exxosforum.co.uk/atari/last/GB6/index.htm
leon22
Post by leon22 »
exxos wrote: Mon Jan 21, 2019 8:37 pm Very strange...
No, TOS206 never worked (not with 16MHz and also not with 8MHz -> same behaviour)
exxos wrote: Mon Jan 21, 2019 8:37 pm Can you boot TOS104 and run GB6 for a couple hours and see if TOS104 is stable at 16MHz..
Ok, will try!
leon22 wrote: Mon Jan 21, 2019 8:50 pm No, TOS206 never worked (not with 16MHz and also not with 8MHz -> same behaviour)
Ah ok, that makes a lot more sense then.. I thought you had it running with TOS206 at 8MHz...
leon22 wrote: Mon Jan 21, 2019 8:50 pm Should I run something or just the desktop?
Its probably not worth it I think now... 16MHz is working with TOS104, so either some problem with the floppy drive or the ROM is bad.
The problem is with the ROM being bad, is they are all verified, so it would seem unlikely. With the floppy drive working with TOS104, it would seem unlikely to be that either.
Which ROM was it you installed, this one ? https://www.exxosforum.co.uk/atari/store2/#0049 (0049) I will burn a new ROM here and see if I have the same issue here... Then at least I know the ROM file I used is good or not...
leon22
Post by leon22 »
exxos wrote: Mon Jan 21, 2019 9:09 pm Which ROM was it you installed, this one ? https://www.exxosforum.co.uk/atari/store2/#0049 (0049) I will burn a new ROM here and see if I have the same issue here... Then at least I know the ROM file I used is good or not...
[0053] German
leon22 wrote: Mon Jan 21, 2019 9:26 pm [0053] German
I just tried a German one and it boots fine on my machine.
I've sent you a PM.
This machine arrived today so I had a look at it..
I used my own PSU & floppy drive testing as they are known working.
I confirm when TOS206 is booted, it crashes just after memory test.
I heard the floppy drive clunk three times which immediately made me think this is not correct and it has some DMA issue. So I proceeded to put the 10K pull up fix on the databus and now the floppy drive clunks once which is normal operation and now the crash has gone.
Obviously TOS206 things the floppy drive is not connected and as it normally does, gives bombs. However the floppy drive is obviously connected, but the data coming back is corrupted making TOS206 the drive is not connected.
As to why this issue only shows up with TOS206 is a mystery. But I am currently seeing such oddities with my current booster research anyway.
I really think everyone should do this modification to their machine and I am classing it as mandatory now.
I even did a video :)
Maybe we should have the new counter which says "This forum has gone zero days without a DMA issue" :lol:
leon22
Post by leon22 »
Good to hear you were able to fix this weird issue!
I'm also thankful that my problem help others to avoid such difficulties!
