Einstein a Go-Go
Re: Einstein a Go-Go
Left SHIFT switch is now removed and fitted in the H position.
All is working well, though there were a few switches playing up still, so I have put some contact cleaner in and after a bit of repeat operation they have all started working nicely.
I've found what appears to be a new Alps SKCC key switch on eBay that visually at least is a very good match, so once I get it and proved it good (or bad) I'll update on here as to the switch type.
I do have a box of Cherry MX switches that seem to have the same keycap fitting, but they neither fit the keycap or the PCB. I have BBC B key switches too and they don't fit either, which is annoying!!
Next up I need to sort out the Gotek.
Interestingly it came with 2 FDD cables so I at least have those as a starting point. Well those and the drawer full of cables I have...
I also did some preventative maintenance on the PSU as recommended by somebody over at Vintage-radio.net, which was to replace CE05 for a 105C version rather than an 85C version, and to check both RE08 and RE10 were within tolerance (5%), which they were.
Fingers crossed that'll run for another 40+ years :)
And we are now operational with a Gotek:
You could try drilling a 1mm hole in both parts of the post and fit a piece of cut-off paper clip wire in there with a small dab of epoxy on the end of the wire as you push it into the holes.
rubber_jonnie wrote: Fri Nov 20, 2026 3:52 pm And we are now operational with a Gotek:
Those TMS VDP colours... recognisable anywhere.
stephen_usher wrote: Fri Nov 20, 2026 6:37 pm You could try drilling a 1mm hole in both parts of the post and fit a piece of cut-off paper clip wire in there with a small dab of epoxy on the end of the wire as you push it into the holes.
I'm keeping that idea on the back burner as I have a new switch coming from eBay, but I need to keep my options open.
stephen_usher wrote: Fri Nov 20, 2026 6:38 pm
100%
If I didn't know better I'd think I was looking at my Colecovision!!!
Well, definitely moving forwards here, I now have the Gotek installed and working I just need to get the key fixed (Parts on the way) and it's done pretty much other than a better display hookup since it's just using an UHF to HDMI adapter right now.
And with the lid back on:
Post by HigashiJun »
:dualthumbup:
