I have always wondered how the graphics in Super Cars II were done, because no ripper I ever tried could find a single standard graphic in it. My real aim is a level editor so we can add new tracks, but I assumed working out the level format would be close to impossible. So I threw my own dump of the disk at Claude and asked it to dig in. It turns out it was not impossible at all.
Step 1 - getting the files off the disk
The disk is a normal 10 sector per track TOS disk with a protection track at 79, so once the STX image was decoded, all the files came straight off it. There is a small loader in the AUTO folder, the main game (CARS.REL) and about a hundred files called FILExx.SCR.
Step 2 - why rippers find nothing
Every graphics file is packed with Magnetic Fields' own packers, which start with "SP", "SA" or "SF" headers. On top of that, the SP graphics unpack into whole separate bitplanes rather than the normal ST interleaved screen layout, so even unpacked they do not look like ST graphics. No wonder the rippers gave up, they were looking for something that was never there.
The unpack routines were taken straight out of the game code and ported line for line. Every file now unpacks without errors, and the title screens come out perfectly, which proved the depackers were right.
Step 3 - the collision / height map
Each course has a 32KB map with 4 cells per 16 pixel tile. You can clearly see the track shape, bridges and crossovers in it. The best guess so far is two height values (upper and lower layer) plus a surface type, but that part is NOT confirmed yet and needs more digging in the race code.
Step 4 - the scenery tiles
There are three scenery sets, each made of sheets of 256 tiles at 16x16 pixels. The game code shows which files get loaded for each race and which palette goes with each set.
Step 5 - the track maps
Each course also has an 8KB tile map, a 64x64 grid of tile numbers, with the actual course using part of it (from 20x50 up to 64x16 tiles). Put that together with the right tile set and palette and out pop all 21 courses in full colour. Some of the maps even still have the designer's size notes like "32 x 32" drawn in tiles outside the track area, which was a nice touch from 1991.
Here is Bagley Marsh, the first race, at full size:
There is also a course database file which still has the original symbol names in it. It holds the race order, which tile set each race uses, lap counts, AI settings, and each course's size, name and description text.
Step 6 - the cars
The cars are pre-rotated sprites, 32 frames per car, with the missiles and explosions in a separate bank that carries its own mask plane. The colours here are only roughly right because I used the track palette for the preview.
What this means for a level editor
The good news is the loader happily accepts files that are not packed, so an edited map can simply be saved back as raw data without having to write a packer. There is about 154KB free on the disk, which is enough for a couple of new or modified tracks.
What is still left to work out is exactly what the values in the collision map mean, and a few tables in the course data that are probably AI routes and gate positions. Once those are pinned down, an editor is very doable.
Not bad for a game that has kept its secrets for 35 years, it only took slightly longer than loading Elite off cassette.
Super Cars II (Atari ST) - finally cracking how the graphics and tracks work
elterwater
Re: Super Cars II (Atari ST) - finally cracking how the graphics and tracks work
Nice work, well done
My best friend and I used to love lobbing missiles at each other on these tracks
Yeah, I built a "auto flobber" just for supercars for constant firingelterwater wrote: Sun Oct 18, 2026 11:02 pm Nice work, well done
My best friend and I used to love lobbing missiles at each other on these tracks![]()
My problem was, I suck at games, and could only manage the easy levels. hence always wanting a track editor.
Mostly I am plotting a STE edition currently as a first build, but time is limited, so not sure how quick it will happen.
STE hardware scrolling test
I'm too lazy to do a animation or video. But it scrolls to the left every 1 pixel very smoothly
none of that pre-rendering using lots of RAM nonsense
Prototype STE engine
Yeah colours are a bit messed up etc, but its a proof of concept at this point
First the AI track data was extracted.. ohh AI back in 1991 !!
Then a demo..
So that is actually a compiled PRG of the STE engine
Then a demo..
