Yes, I'm using an ATF16 w/ U68turbo.jedexxos wrote: Wed Nov 18, 2026 2:21 pm The scores look normal but flashing 106 is only half the fix. You need to update the falcon gal firmware as well.
Slow DSP investigation with DFB1
Re: Slow DSP investigation with DFB1
Whomper
Homepage
Electronic Lab
16 Bit: Falcon (DFB1X/14MB/4+8 GB), 1040STFM, Soundpool SPDIF/FA8, Cubase Audio, Cubase 3
8 Bit: 1200XL, 800XL, 2 x 1050, 1025, Fujinet Pro, 2 x 1010, CX-85, Touch Tablet
Homepage
Electronic Lab
Whoa.whomper wrote: Wed Nov 18, 2026 9:31 am Some more fun with the board in 16 MHz mode and Cubase Audio with a few files;
Video 1
Video 2
Video 3
In past with original U68 and FW 1.04 it took Cubase a few minute to get to this situation. Now it happens as I start the music.
Is there any way to see that DFB1X has the latest 1.06 firmware and the flash was successful?
Yeah, that's very wrong.
What I'm not seeing is the DSACK0 activity light (the third LED) indicating any DSP accesses at all. Bus mastery is for the most part behaving as it ought until you get the occasional longer outage and then what appears to be a reset.
You know, I would almost go as far to wonder if DFB1 isn't actually running the software at all and you're seeing the results of the onboard processor being fought with.
It sounds like your flashing process was fraught with issues. Perhaps try the xc3sprog (available on Homebrew) natively instead of flashing from Windows?
Also I'd unseat DFB1, clean the hell out of the contacts on both board and motherboard and reseat again.
