Slow DSP investigation with DFB1
pakman
Re: Slow DSP investigation with DFB1
Post by pakman »
Badwolf wrote: Fri Nov 06, 2026 9:45 am Holger, @pakman (pakman with a K not a C)
And by the way "Parkman" is also wrong..
(Maybe I should better change my name to PAKman, since it refers to the PAK68/3 published in the german ct magazine back in 1994).
We can ask for permission to ship programmed gals with DFB1Xs, but I've not heard back from him for a long time. I hope he's OK.
Permission granted!
viking272
Post by viking272 »
pakman wrote: Fri Nov 06, 2026 8:15 pm Permission granted!
Amazing, thank you! πŸ™ πŸ™
:dualthumbup: :thanksyellow:
viking272
Post by viking272 »
exxos wrote: Thu Nov 05, 2026 11:04 pm Its not on sale on my store.. Partly because I can't find any GALs. I've got the Atmel ones in my mouser basket but i had given up trying to program them as the power down pin was always enabled. But I've got a different programmer now. So worth another try.
Hi @exxos
Did you manage to test your different programmer?
Just wondering if it got around the power down pin issue?
Is the u68 GAL socketed or a solder job?
viking272 wrote: Mon Nov 09, 2026 9:36 am Did you manage to test your different programmer?
I haven't got any chips to test yet.. They are in my mouser basket but I'm not ready to do the order yet
charon030
Post by charon030 »
mikro wrote: Sun Nov 01, 2026 12:02 pm
Nembench results when accessing ST RAM (MByte/s):
  β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”
  β”‚               Test                β”‚ DFB1X  β”‚  CT2   β”‚  Ξ”   β”‚
  β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€
  β”‚ Linear 32bit read ST-RAM          β”‚  5.297 β”‚ 10.240 β”‚ +93% β”‚
  β”‚ Linear 32bit write ST-RAM         β”‚  6.406 β”‚ 11.477 β”‚ +79% β”‚
  β”‚ Linear 32bit copy ST-RAM          β”‚  3.209 β”‚  5.738 β”‚ +79% β”‚
  β”‚ Linear 16bit read ST-RAM          β”‚  4.890 β”‚  9.256 β”‚ +89% β”‚
  β”‚ Linear 16bit write ST-RAM         β”‚  5.779 β”‚ 11.497 β”‚ +99% β”‚
  β”‚ Linear 16bit copy ST-RAM          β”‚  2.066 β”‚  3.828 β”‚ +85% β”‚
  β”‚ Linear 8bit read ST-RAM           β”‚  4.190 β”‚  6.660 β”‚ +59% β”‚
  β”‚ Linear 8bit write ST-RAM          β”‚  2.894 β”‚  5.748 β”‚ +99% β”‚
  β”‚ Linear 8bit copy ST-RAM           β”‚  1.034 β”‚  1.914 β”‚ +85% β”‚
TL;DR version:
- ST-RAM: about 1.6x - 2.0x faster on CT2
I wonder whether the faster ST-RAM accesses are only related to bus-overclocking.
At least for the CT60, Rodolphe emphasized that the ST-RAM write accesses are carried out in 3 instead of 4 clock cycles. https://mikrosk.github.io/ct60tos/ct60/ ... hs_eng.htm
Maybe that trick was already done on the CT2? Or maybe the CT2 did not toggle the CPU clock between 50 MHz and 16 MHz for ST-RAM accesses but sampled the Falcon bus at 50 MHz?
mikro
Post by mikro »
charon030 wrote: Tue Nov 10, 2026 9:11 pm I wonder whether the faster ST-RAM accesses are only related to bus-overclocking.
I'm almost sure that this isn't the case. Of course it helps but it isn't the whole story. I have got another Falcon with a Phantom@25 MHz so if I find time to switch the setups (I've got other things to try there, too) I can re-measure this again. I'll make a TODO note.
Return to β€œDSTB1 & DFB1 booster by BadWolf”
